[SOLVED] Regression: random 500 sync/create schema
  • [x ] Regression (a behavior that stopped working in a new release)
  • [ ] Bug report
After cloud upgrade REST API calls Synchronize a schema / create schema / update schema rules fails with HTTP 500. It’s strange behavior because it seems totally random. Sometimes i send 5 schema sync requests and all fails and next time fails only one of requests. I do about ~20 requests in short time.
example response data:
{ traceId: '|334b6cb0-4ad48530724be93e.', type: 'https://tools.ietf.org/html/rfc7231#section-6.6.1', statusCode: 500 }
schema data (json) are not changed.
Work as in previous version.
POST https://cloud.squidex.io/api/apps/{app}/schemas
  • [ ] Self hosted with docker
  • [x ] Cloud version
Version: cloud
Browser: N/A
Also when i am trying to create new field or delete schema, sometimes i have error (red) notification XXX reload page.
Thank you.
Josef
Hi, it is the same as this: Not able to add fields to schema
I just deployed a potential fix.
Yes, it’s solved.
Thank you.
