- [X] Bug report
Requests from some requests of the CLI are sent to the domain without the folder /cms/. If that calls gets a redirect the operation fails. Example of these calls:
dev.example.com 172.16.53.1 - - [21/Apr/2022:10:04:56 +0000] “GET /api/apps HTTP/1.1”
dev.example.com 172.16.53.1 - - [21/Apr/2022:10:05:25 +0000] “GET /api/apps/homes/schemas HTTP/1.1”
dev.example.com 172.16.53.1 - - [21/Apr/2022:10:05:38 +0000] “GET /api/apps/homes/schemas HTTP/1.1”
dev.example.com 172.16.53.1 - - [21/Apr/2022:10:10:19 +0000] "GET /api/apps/homes/assets/folders?parentId=00000000-0000-0000-0000-000000000000
I have tried with configs with ending slash and without, an the results are the same:
https://www.example.com/cms
https://www.example.com/cms/
Requests are made to the URL set in sq config add. (https://www.example.com/cms/). So the above requests should be:
“GET /cms/api/apps HTTP/1.1”
“GET /cms/api/apps/homes/schemas HTTP/1.1”
"GET /cms/api/apps/homes/assets/folders?parentId=00000000-0000-0000-0000-000000000000
Use a url parameter with a path in the URL:
App Name: homes
- [X] Self hosted with docker
CLI 8.8.0
- [ ] Chrome (desktop)
