[x] Bug report
[ ] Performance issue
If I have a scheme with an array and inside that array a radio checkbox, if I change one radio checkboxes value, all the other change as well.
Only the one radio checkbox, that I edit should be changing.
- create a schema with an array and inside that array a radio input field
- create an element with that schema and add two items for the array
- change the radio button value
- [x] Cloud version
- [x] Chrome (desktop)
