When creating content that has a references field with a default value specified it is not populated with the default.
When creating content that has a references field with a default value specified it is populated with the default.
- Create a ‘References’ type field
- Set a ‘Default Value’ to be the content ID of a valid schema
- Create a new record for the schema and see the ‘References’ field has not been populated with the ‘Default Value’
App Name: corecms
- [x] Self hosted with docker
Version: 6.3.0
- [X] Chrome (desktop)
I only thought this might be possible after seeing this other feature request being marked as ‘[IMPLEMENTED]’: [IMPLEMENTED] Default value(s) for reference fields
However after looking through code and commit history around the time that request was worked on I cannot find out how to do it. Tried with every editor and also other field values in case it matched on text. Apologies if I am missing something obvious!
