Hello, would like to request a “Default value” feature for Component field.
Not first time this need occurs.
There are some topics around Default value for Reference fields.
And this one says it’s implemented for Component field.
[SOLVED] Default value(s) for reference fields - how to use this functionality?
But, there’s no any sign of availabity to set the Default value.
Taking UI as base example - lacks of “Default value” within Validation tab.
Explored also the SDK seems not to support it.
