[SOLVED] Component - Not a Known Field Validation Error
  • [x] Checked the logs and have uploaded a log file and provided a link because I found something suspicious there. Please do not post the log file in the topic because very often something important is missing.
  • [x] Bug report
Adding a new field to an existing component tied to a single content schema already saved produces a validation error “Not a known field”.
Save does not throw not a know field validation error.
Simple app duplicating issue can be seen https://cloud.squidex.io/app/not-a-known-field-bug
  1. Create a component (add a string field called “string1”)
  2. Create a single content schema (add a component field and point to created component)
  3. Go to content and save a test string in the original component.
  4. Go back to schema editor and edit component. Add a new field that is a string called “string2”.
  5. Go back to content and try to save a new value in string2, a validation error appears.
  • [x] Self hosted with docker
  • [x] Cloud version
Version: latest on both
  • [x] Chrome (desktop)
Since this is a validation error, I have no error log to share.
I attempted to use the Json synchronize option for both the component and schema (with delete and recreate fields both checked) but this did not change the result. Note, I set isPublished to false in the json text when doing this to ensure the synchronize had a change to go forward.
Apologies for the updates on original post. I removed the work-around I listed as it doesn’t appear to work in all cases. Not able to reliably reproduce a workaround.
Do you have the json for me?
Thx, it is a caching issue and a architectural flaw. Unfortunately I do not have a fast solution, so it might take a little bit of time to resolve that issue.
Sorry about that, will include in future if find any bugs. In terms of resolve time, no problem.
It is fixed in the master branch
Thank you.
We updated our version, and I can confirm the fix works.
