- [x] Bug report
The ‘Clear’ button is still clickable when the field is disabled and you are able to remove all the components.
“Clear” button is disabled like other buttons that change content on the page when field is disabled.
- Create schema with a Components field
- Create content for that schema including a component or two in the components field and publish
3a. Assign schema to a workflow that has ‘Prevent updates’ checked against the Published status; OR
3b. Click ‘Disable in UI’ for the components field - Go back to the content; you can click the ‘Clear’ button and remove that bit of content (after clicking ‘Yes’ in the popup if you haven’t previously selected “Don’t ask again”).
- [x] Self hosted with docker
- [x] Cloud version
Version: Cloud & 7.1.0
- [x] Chrome (desktop)
I raised this last week but I cannot find it as I think it was deleted as the version I had reported it against was 6.9.0 and you have made changes in this area in commits since then (For example [SOLVED] Disabled fields still have x button (clear field content) enabled), but I have retested against latest versions and the bug is still present. It is not a major issue as you cannot save the changes after clearing the field.
… will be fixed as well.
