Reference field UI only listing first schema type even though multiple types are allowed
  • Checked the logs and have provided the logs if I found something suspicious there
I have a reference field in a schema that can accept multiple other schemas.
JSON Below
“properties”: {},
“scripts”: {},
“fieldsInLists”: [],
“fieldsInReferences”: [],
“fields”: [
“name”: “title”,
“properties”: {
“fieldType”: “String”,
“editor”: “Input”,
“contentType”: “Unspecified”,
“label”: “Title”
“partitioning”: “invariant”
“name”: “slug”,
“properties”: {
“editor”: “Input”,
“name”: “content”,
“properties”: {
“fieldType”: “References”,
“editor”: “Checkboxes”,
“schemaIds”: [
“f1344f30-2644-4fae-b77d-bc5d7eb0a0f3”,
“f5754203-1287-4bd3-9f17-0c567ed775b9”
“label”: “Content”
“isPublished”: true
In the Content UI, I am unable to see the other content items of the allowed schemas, it only shows the 1st schema type in the list
In the Content UI > Add New or Select Exsiting Modal I should see all content items from all allowed schemas, I should see the All other content items from the allowed schema
  • Create 3 schemas
  • faq-item
  • paragraph-item
  • page
  • In page schema add a reference field that allows faq-item’s and paragraph-item’s
  • Create a faq-item content
  • Create a paragraph-item content
  • Create new page content and click Select Existing
Self hosted with docker
Version: 5.0.0
Browser: Edge Chromium
In the header of the dialog you see “select faq-item”, you can also select another schema there.
Are yes… I total forgot that … !
I will add it as a note to: [WIP] Design modernization
Just needs a little twisty icon next to the text.
Yes, I have changed it already.
