I am trying to show a referenced value in the content list, but it is just showing as “1 References”
This is a 1:1 reference, however the only way I know so far to make a 1:1 reference is by setting the constraints for min and max items to both be 1. is there a better way? I suspect this may be the problem, and it’s inferring that this is a 1:M reference.
In the referenced schema, I have the ‘name’ string field set to be the ‘Reference Field’, but this does not change the display.
I expected to see the name value instead of “1 References”
This issue is related, but it’s flagged as implemented to I am opening a new issue:
[ x] Checked the logs and have provided the logs if I found something suspicious there
[ ?] Regression (a behavior that stopped working in a new release)
[ x] Bug report
[ ] Performance issue
I see “1 References”
ok so that’s what I have it set to. I guess what threw me off is that the data implies it’s still a 1:m reference because it’s a list of items not just one item. ex:
iv: [name] and not iv: name
In any case, that’s not the actual focus of the issue here, just a side tangent. I’m still unable to see the name value in the UI list when it’s being referenced.
Is there something I’m doing wrong, or is this a bug?
When the reference is an asset, the editing tab shows resolve image and not resolve reference, but I don’t have an image. I would like to see the file or slug name be resolved instead.
When the reference is a 1:1 reference, This works as expected now.
