I am installing Squidex via Kubernetes Helm chart on Open Telekom Cloud hosting service.
The installation fails to spin up the requested pods. Specifically the Squidex pod (not the mongo DB pods which I got working by changing storageClass to csi-disk, as Open Telekom supports).
The pods fails with Exit Code 139. Here is what I have found about that error code;
- This indicates that container received SIGSEGV
- SIGSEGV indicates a segmentation fault. This occurs when a program attempts to access a memory location that it’s not allowed to access, or attempts to access a memory location in a way that’s not allowed.
- From the Docker container standpoint, this either indicates an issue with the application code or sometimes an issue with the base images used by the container.
We got Squidex running on http, but not https a while ago.
But when we tried retracing our steps, we could not get it working again. So we are not sure how. This also indicates to me, that it might be cloud provider issue, and not Squidex code as presume when reading about error code 139 above
Error log:
{"logLevel":"Information","message":"Application started","environment":{"applicationname":"Squidex","aspnetcore_urls":"http://\u002B:80","aspnet_version":"5.0.0","assets:defaultpagesize":"200","assets:deletepermanent":"False","assets:deleterecursive":"True","assets:folderperapp":"False","assets:maxresults":"200","assets:maxsize":"5242880","assets:timeoutfind":"00:00:01","assets:timeoutquery":"00:00:05","assetstore:amazons3:accesskey":"\u003CMY_KEY\u003E","assetstore:amazons3:bucket":"squidex-test","assetstore:amazons3:bucketfolder":"squidex-assets","assetstore:amazons3:forcepathstyle":"False","assetstore:amazons3:regionname":"eu-central-1","assetstore:amazons3:secretkey":"\u003CMY_SECRET\u003E","assetstore:amazons3:serviceurl":"","assetstore:azureblob:connectionstring":"UseDevelopmentStorage=true","assetstore:azureblob:containername":"squidex-assets","assetstore:exposesourceurl":"False","assetstore:folder:path":"Assets","assetstore:ftp:password":"","assetstore:ftp:path":"Assets","assetstore:ftp:serverhost":"","assetstore:ftp:serverport":"21","assetstore:ftp:username":"","assetstore:googlecloud:bucket":"squidex-assets","assetstore:mongodb:bucket":"fs","assetstore:mongodb:configuration":"mongodb://localhost","assetstore:mongodb:database":"SquidexAssets","assetstore:type":"MongoDb","caching:maxsurrogatekeyssize":"0","caching:replicated:enable":"True","caching:strongetag":"False","contentroot":"/app","contents:defaultpagesize":"200","contents:maxresults":"200","contents:timeoutfind":"00:00:01","contents:timeoutquery":"00:00:05","dotnet_running_in_container":"true","dotnet_version":"5.0.0","email:notifications:existinguserbody":"Dear User,\r\n\r\n$ASSIGNER_NAME ($ASSIGNER_EMAIL) has invited you to join App $APP_NAME at Squidex Headless CMS.\r\n\r\nLogin or reload the Management UI to see the App.\r\n\r\nThank you very much,\r\nThe Squidex Team\r\n\r\n\u003C\u003CStart now!\u003E\u003E [$UI_URL]","email:notifications:existingusersubject":"[Squidex CMS] You have been invited to join App $APP_NAME","email:notifications:newuserbody":"Welcome to Squidex\r\nDear User,\r\n\r\n$ASSIGNER_NAME ($ASSIGNER_EMAIL) has invited you to join Project (also called an App) $APP_NAME at Squidex Headless CMS. Login with your Github, Google or Microsoft credentials to create a new user account and start editing content now.\r\n\r\nThank you very much,\r\nThe Squidex Team\r\n\r\n\u003C\u003CStart now!\u003E\u003E [$UI_URL]","email:notifications:newusersubject":"You have been invited to join Project $APP_NAME at Squidex CMS","email:notifications:usagebody":"Dear User,\r\n\r\nYou you are about to reach your usage limit for App $APP_NAME at Squidex Headless CMS.\r\n\r\nYou have already used $API_CALLS of your monthy limit of $API_CALLS_LIMIT API calls.\r\n\r\nPlease check your clients or upgrade your plan!\r\n\r\n\u003C\u003CGo to Squidex!\u003E\u003E [$UI_URL]","email:notifications:usagesubject":"[Squidex CMS] You you are about to reach your usage limit for App $APP_NAME","email:smtp:enablessl":"True","email:smtp:password":"","email:smtp:port":"587","email:smtp:sender":"hello@squidex.io","email:smtp:server":"","email:smtp:username":"","eventpublishers:alltorabbitmq:configuration":"amqp://guest:guest@localhost/","eventpublishers:alltorabbitmq:enabled":"False","eventpublishers:alltorabbitmq:eventsfilter":".*","eventpublishers:alltorabbitmq:exchange":"squidex","eventpublishers:alltorabbitmq:type":"RabbitMq","eventstore:mongodb:configuration":"mongodb://squidex-1646399944-mongodb-replicaset-0.squidex-1646399944-mongodb-replicaset.app.svc.cluster.local,squidex-1646399944-mongodb-replicaset-1.squidex-1646399944-mongodb-replicaset.app.svc.cluster.local,squidex-1646399944-mongodb-replicaset-2.squidex-1646399944-mongodb-replicaset.app.svc.cluster.local","eventstore:mongodb:database":"Squidex","eventstore:type":"MongoDb","exposedconfiguration:version":"squidex:version","fulltext:elastic:configuration":"http://localhost:9200","fulltext:elastic:indexname":"squidex","fulltext:type":"default","healthz:gc:threshold":"4096","home":"/root","hostname":"squidex-1646399944-574f5b58d4-xxt8k","identity:adminclientid":"","identity:adminclientsecret":"","identity:adminemail":"rasmuslc@brain-plus.com","identity:adminpassword":"Represent","identity:adminrecreate":"true","identity:allowpasswordauth":"true","identity:githubclient":"211ea00e726baf754c78","identity:githubsecret":"d0a0d0fe2c26469ae20987ac265b3a339fd73132","identity:googleclient":"1006817248705-t3lb3ge808m9am4t7upqth79hulk456l.apps.googleusercontent.com","identity:googlesecret":"QsEi-fHqkGw2_PjJmtNHf2wg","identity:lockautomatically":"false","identity:microsoftclient":"b55da740-6648-4502-8746-b9003f29d5f1","identity:microsoftsecret":"idWbANxNYEF4cB368WXJhjN","identity:microsofttenant":"","identity:oidcauthority":"","identity:oidcclient":"","identity:oidcgetclaimsfromuserinfoendpoint":"false","identity:oidcmetadataaddress":"","identity:oidcname":"OIDC","identity:oidconsignoutredirecturl":"","identity:oidcresponsetype":"id_token","identity:oidcscopes":"[]","identity:oidcscopes:0":"email","identity:oidcsecret":"","identity:privacyurl":"https://squidex.io/privacy","identity:showpii":"true","kafka:bootstrapservers":"","kubernetes_port":"tcp://10.247.0.1:443","kubernetes_port_443_tcp":"tcp://10.247.0.1:443","kubernetes_port_443_tcp_addr":"10.247.0.1","kubernetes_port_443_tcp_port":"443","kubernetes_port_443_tcp_proto":"tcp","kubernetes_service_host":"10.247.0.1","kubernetes_service_port":"443","kubernetes_service_port_https":"443","languages:custom":"","logging:applicationinsights:connectionstring":"InstrumentationKey=[key];IngestionEndpoint=https://[datacenter].in.applicationinsights.azure.com/","logging:applicationinsights:enabled":"false","logging:colors":"false","logging:human":"false","logging:level":"INFORMATION","logging:logrequests":"true","logging:otlp:enabled":"false","logging:otlp:endpoint":"","logging:stackdriver:enabled":"false","logging:storeenabled":"true","logging:storeretentationindays":"90","logging:storeretentionindays":"90","mode:isreadonly":"False","news:appname":"squidex-website","news:clientid":"squidex-website:default","news:clientsecret":"QGgqxd7bDHBTEkpC6fj8sbdPWgZrPrPfr3xzb3LKoec=","notifo:apikey":"","notifo:apiurl":"https://app.notifo.io","notifo:appid":"","orleans:clustering":"MongoDB","orleans:gatewayport":"40000","orleans:ipaddress":"","orleans:kubernetes":"true","orleans:siloport":"11111","orleans_cluster_id":"squidex","orleans_service_id":"squidex-5.9.0","paas_pod_id":"afeff30b-d5e0-49c1-8ef1-f0b918c13d33","path":"/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin","plugins:0":"Squidex.Extensions.dll","pod_ip":"172.16.0.106","pod_name":"squidex-1646399944-574f5b58d4-xxt8k","pod_namespace":"app","rebuild:apps":"False","rebuild:assetfiles":"False","rebuild:assets":"False","rebuild:contents":"False","rebuild:indexes":"False","rebuild:rules":"False","rebuild:schemas":"False","robots:text":"User-agent: *\nAllow: /api/assets/*","rules:executiontimeoutinseconds":"10","running_in_container":"true","squidex_1646399944_port":"tcp://10.247.205.20:80","squidex_1646399944_port_80_tcp":"tcp://10.247.205.20:80","squidex_1646399944_port_80_tcp_addr":"10.247.205.20","squidex_1646399944_port_80_tcp_port":"80","squidex_1646399944_port_80_tcp_proto":"tcp","squidex_1646399944_service_host":"10.247.205.20","squidex_1646399944_service_port":"80","squidex_1646399944_service_port_http":"80","store:mongodb:configuration":"mongodb://squidex-1646399944-mongodb-replicaset-0.squidex-1646399944-mongodb-replicaset.app.svc.cluster.local,squidex-1646399944-mongodb-replicaset-1.squidex-1646399944-mongodb-replicaset.app.svc.cluster.local,squidex-1646399944-mongodb-replicaset-2.squidex-1646399944-mongodb-replicaset.app.svc.cluster.local","store:mongodb:contentdatabase":"SquidexContent","store:mongodb:database":"Squidex","store:type":"MongoDb","translations:deepl:authkey":"","translations:deepl:mapping:zh-cn":"zh-CN","translations:deepl:mapping:zh-tw":"zh-TW","translations:googlecloud:projectid":"","twitter:clientid":"QZhb3HQcGCvE6G8yNNP9ksNet","twitter:clientsecret":"Pdu9wdN72T33KJRFdFy1w4urBKDRzIyuKpc0OItQC2E616DuZD","ui:google:analyticsid":"UA-99989790-2","ui:hidedatebuttons":"False","ui:hidedatetimemodebutton":"False","ui:hidenews":"False","ui:hideonboarding":"False","ui:map:googlemaps:key":"AIzaSyB_Z8l3nwUxZhMJykiDUJy6bSHXXlwcYMg","ui:map:type":"OSM","ui:onlyadminscancreateapps":"False","ui:redirecttologin":"False","ui:referencesdropdownitemcount":"100","ui:regexsuggestions:email":"^[a-zA-Z0-9.!#$%\u0026\u2019*\u002B\\/=?^_\u0060{|}~-]\u002B@[a-zA-Z0-9-]\u002B(?:.[a-zA-Z0-9-]\u002B)*$","ui:regexsuggestions:phone":"^\\(*\\\u002B*[1-9]{0,3}\\)*-*[1-9]{0,3}[-. /]*\\(*[2-9]\\d{2}\\)*[-. /]*\\d{3}[-. /]*\\d{4} *e*x*t*\\.* *\\d{0,4}$","ui:regexsuggestions:slug":"^[a-z0-9]\u002B(\\-[a-z0-9]\u002B)*$","ui:regexsuggestions:url":"^(?:http(s)?:\\/\\/)?[\\w.-]\u002B(?:\\.[\\w\\.-]\u002B)\u002B[\\w\\-\\._~:\\/?#%[\\]@!\\$\u0026\u0027\\(\\)\\*\\\u002B,;=.]\u002B$","ui:showinfo":"False","urls":"http://\u002B:80","urls:basepath":"","urls:baseurl":"https://frontend.80.158.54.207.nip.io/webapp3","urls:enableforwardheaders":"True","urls:enforcehost":"False","urls:enforcehttps":"true","version":"5.0.0","webapp1_svc_port":"tcp://10.247.201.77:80","webapp1_svc_port_80_tcp":"tcp://10.247.201.77:80","webapp1_svc_port_80_tcp_addr":"10.247.201.77","webapp1_svc_port_80_tcp_port":"80","webapp1_svc_port_80_tcp_proto":"tcp","webapp1_svc_service_host":"10.247.201.77","webapp1_svc_service_port":"80","webapp2_svc_port":"tcp://10.247.230.227:80","webapp2_svc_port_80_tcp":"tcp://10.247.230.227:80","webapp2_svc_port_80_tcp_addr":"10.247.230.227","webapp2_svc_port_80_tcp_port":"80","webapp2_svc_port_80_tcp_proto":"tcp","webapp2_svc_service_host":"10.247.230.227","webapp2_svc_service_port":"80"},"timestamp":"2022-03-04T13:22:11Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"b613383d-269d-4c31-91e6-4b86331559c1"}}
{"logLevel":"Information","initialize":["ValidationInitializer","SerializationInitializer","LanguagesInitializer","MongoAssetFolderRepository","MongoAssetRepository","MongoContentRepository","MongoEventStore","MongoGridFsAssetStore","MongoHistoryEventRepository","MongoMigrationStatus","MongoRequestLogRepository","MongoRoleStore","MongoRuleEventRepository","MongoSchemasHash","MongoTextIndex","MongoTextIndexerState","MongoUsageRepository","MongoUserStore","TokenStoreInitializer","CreateAdminInitializer"],"timestamp":"2022-03-04T13:22:11Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"b613383d-269d-4c31-91e6-4b86331559c1"}}
{"logLevel":"Information","initializedSystem":"ValidationInitializer","timestamp":"2022-03-04T13:22:11Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"b613383d-269d-4c31-91e6-4b86331559c1"}}
{"logLevel":"Information","initializedSystem":"SerializationInitializer","timestamp":"2022-03-04T13:22:11Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"b613383d-269d-4c31-91e6-4b86331559c1"}}
{"logLevel":"Information","initializedSystem":"LanguagesInitializer","timestamp":"2022-03-04T13:22:11Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"b613383d-269d-4c31-91e6-4b86331559c1"}}
{"logLevel":"Information","initializedSystem":"MongoAssetFolderRepository","timestamp":"2022-03-04T13:22:11Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"b613383d-269d-4c31-91e6-4b86331559c1"}}
{"logLevel":"Information","initializedSystem":"MongoAssetRepository","timestamp":"2022-03-04T13:22:11Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"b613383d-269d-4c31-91e6-4b86331559c1"}}
{"logLevel":"Information","initializedSystem":"MongoContentRepository","timestamp":"2022-03-04T13:22:11Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"b613383d-269d-4c31-91e6-4b86331559c1"}}
{"logLevel":"Information","initializedSystem":"MongoEventStore","timestamp":"2022-03-04T13:22:11Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"b613383d-269d-4c31-91e6-4b86331559c1"}}
{"logLevel":"Error","message":"QueueWorkItem was called on a non-null context [SystemTarget: S172.16.0.106:11111:384096130*stg/13/0000000d@S0000000d] but there is no valid WorkItemGroup for it.","eventId":{"id":101231},"timestamp":"2022-03-04T13:22:41Z","app":
{"name":"Squidex","version":"5.9.0.0","sessionId":"b613383d-269d-4c31-91e6-4b86331559c1"},"category":"Orleans.Runtime.Scheduler.OrleansTaskScheduler"}
Unhandled exception. System.TimeoutException: A timeout occurred after 30000ms selecting a server using CompositeServerSelector{ Selectors = MongoDB.Driver.MongoClient+AreSessionsSupportedServerSelector, LatencyLimitingServerSelector{ AllowedLatencyRange = 00:00:00.0150000 }, OperationsCountServerSelector }. Client view of cluster state is { ClusterId : "1", Type : "Unknown", State : "Disconnected", Servers : [{ ServerId: "{ ClusterId : 1, EndPoint : "Unspecified/localhost:27017" }", EndPoint: "Unspecified/localhost:27017", ReasonChanged: "Heartbeat", State: "Disconnected", ServerVersion: , TopologyVersion: , Type: "Unknown", HeartbeatException: "MongoDB.Driver.MongoConnectionException: An exception occurred while opening a connection to the server.
---> System.Net.Sockets.SocketException (101): Network is unreachable
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.CreateException(SocketError error, Boolean forAsyncThrow)
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ConnectAsync(Socket socket)
at System.Net.Sockets.Socket.ConnectAsync(EndPoint remoteEP, CancellationToken cancellationToken)
at System.Net.Sockets.Socket.ConnectAsync(EndPoint remoteEP)
at MongoDB.Driver.Core.Connections.TcpStreamFactory.ConnectAsync(Socket socket, EndPoint endPoint, CancellationToken cancellationToken)
at System.Runtime.CompilerServices.AsyncMethodBuilderCore.Start[TStateMachine](TStateMachine& stateMachine)
at MongoDB.Driver.Core.Connections.TcpStreamFactory.CreateStreamAsync(EndPoint endPoint, CancellationToken cancellationToken)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Runtime.CompilerServices.AsyncTaskMethodBuilder`1.AsyncStateMachineBox`1.MoveNext(Thread threadPoolThread)
at System.Threading.Tasks.AwaitTaskContinuation.RunOrScheduleAction(IAsyncStateMachineBox box, Boolean allowInlining)
at System.Threading.Tasks.Task.RunContinuations(Object continuationObject)
at System.Threading.Tasks.Task.FinishSlow(Boolean userDelegateExecute)
at System.Threading.Tasks.Task.TrySetException(Object exceptionObject)
at System.Runtime.CompilerServices.AsyncTaskMethodBuilder`1.SetException(Exception exception, Task`1& taskField)
at System.Threading.Tasks.ValueTask.ValueTaskSourceAsTask.<>c.<.cctor>b__4_0(Object state)
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.InvokeContinuation(Action`1 continuation, Object state, Boolean forceAsync, Boolean requiresExecutionContextFlow)
at System.Net.Sockets.SocketAsyncContext.OperationQueue`1.ProcessSyncEventOrGetAsyncEvent(SocketAsyncContext context, Boolean skipAsyncEvents, Boolean processAsyncEvents)
at System.Net.Sockets.SocketAsyncContext.HandleEvents(SocketEvents events)
at System.Net.Sockets.SocketAsyncEngine.System.Threading.IThreadPoolWorkItem.Execute()
at System.Threading.ThreadPoolWorkQueue.Dispatch()
--- End of stack trace from previous location ---
at MongoDB.Driver.Core.Connections.BinaryConnection.OpenHelperAsync(CancellationToken cancellationToken)
at MongoDB.Driver.Core.Servers.ServerMonitor.InitializeConnectionAsync(CancellationToken cancellationToken)
at MongoDB.Driver.Core.Servers.ServerMonitor.HeartbeatAsync(CancellationToken cancellationToken)", LastHeartbeatTimestamp: "2022-03-04T13:22:41.0998087Z", LastUpdateTimestamp: "2022-03-04T13:22:41.0998089Z" }] }.
at MongoDB.Driver.Core.Clusters.Cluster.ThrowTimeoutException(IServerSelector selector, ClusterDescription description)
at MongoDB.Driver.Core.Clusters.Cluster.WaitForDescriptionChangedHelper.HandleCompletedTask(Task completedTask)
at MongoDB.Driver.Core.Clusters.Cluster.WaitForDescriptionChangedAsync(IServerSelector selector, ClusterDescription description, Task descriptionChangedTask, TimeSpan timeout, CancellationToken cancellationToken)
at MongoDB.Driver.Core.Clusters.Cluster.SelectServerAsync(IServerSelector selector, CancellationToken cancellationToken)
at MongoDB.Driver.MongoClient.AreSessionsSupportedAfterServerSelectionAsync(CancellationToken cancellationToken)
at MongoDB.Driver.MongoClient.AreSessionsSupportedAsync(CancellationToken cancellationToken)
at MongoDB.Driver.MongoClient.StartImplicitSessionAsync(CancellationToken cancellationToken)
at MongoDB.Driver.MongoDatabaseImpl.UsingImplicitSessionAsync[TResult](Func`2 funcAsync, CancellationToken cancellationToken)
at Squidex.Assets.MongoGridFsAssetStore.InitializeAsync(CancellationToken ct)
at Squidex.Hosting.DelegateInitializer.InitializeAsync(CancellationToken ct)
at Squidex.Hosting.InitializerHost.StartAsync(CancellationToken cancellationToken)
at Microsoft.Extensions.Hosting.Internal.Host.StartAsync(CancellationToken cancellationToken)
at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token)
at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.Run(IHost host)
at Squidex.Program.Main(String[] args) in /src/src/Squidex/Program.cs:line 22
Expected behaviour would be that the pods spin up and get to the ready state.
As this might be a problem with the cloud provider, it can be hard to reproduce I guess.
But here are the steps I did on Open Telekom.
-Created a new Cloud Container Engine
-Created a ingress-nginx-controller from the default Helm chart provided by Nginx
-Created cert-manager for https requests
Then I executed the Squidex helm command with a few modifications.
helm install Squidex/squidex --generate-name -f values.yaml
My values.yaml for Squidex:
labels:
service:
type: ClusterIP
port: 80
deployment:
replicaCount: 1
selectors:
component: squidex
partOf: ""
version: ""
image:
repository: squidex/squidex
tag: ""
pullPolicy: IfNotPresent
resources: { }
nodeSelector: { }
tolerations: [ ]
affinity: { }
clusterSuffix: cluster.local
ingress:
## If true, Squidex Ingress will be created.
enabled: false
## Squidex Ingress annotations
annotations:
ingressClassName: ingress-nginx
kubernetes.io/ingress.class: ingress-nginx
kubernetes.io/tls-acme: "true"
hostName: my.domain.com/
tls: [ ]
# - secretName: chart-example-tls
# hosts:
# - chart-example.local
env:
# Define the type of the event store
EVENTSTORE__TYPE: MongoDb
EVENTSTORE__MONGODB__DATABASE: "Squidex"
# CREATE LOCAL ADMIN USER
IDENTITY__ADMINEMAIL: "my@email.com"
IDENTITY__ADMINPASSWORD: "mypassword"
IDENTITY__ADMINRECREATE: "true" # Recreate the admin if it does not exist or the password does not match
IDENTITY__ALLOWPASSWORDAUTH: "true" # Enable password auth. Set this to false if you want to disable local login, leaving only 3rd party login options
IDENTITY__LOCKAUTOMATICALLY: "false" # Lock new users automatically, the administrator must unlock them
IDENTITY__SHOWPII: "true" # Set to true to show PII (Personally Identifiable Information) in the logs
IDENTITY__PRIVACYURL: "https://squidex.io/privacy" # The url to you privacy statements, if you host squidex by yourself
# Settings for Google auth (keep empty to disable)
IDENTITY__GOOGLECLIENT: null
IDENTITY__GOOGLESECRET: null
# Settings for Github auth (keep empty to disable)
IDENTITY__GITHUBCLIENT: null
IDENTITY__GITHUBSECRET: null
# Settings for Microsoft auth (keep empty to disable)
# NOTE: Tennant is optional for using a specific AzureAD tenant
IDENTITY__MICROSOFTCLIENT: null
IDENTITY__MICROSOFTSECRET: null
IDENTITY__MICROSOFTTENANT: null
# Settings for your custom oidc server
IDENTITY__OIDCNAME: null
IDENTITY__OIDCAUTHORITY: null
IDENTITY__OIDCCLIENT: null
IDENTITY__OIDCSECRET: null
IDENTITY__OIDCMETADATAADDRESS: null
IDENTITY__OIDCSCOPES: [] # ["email"]
IDENTITY__OIDCRESPONSETYPE: null # id_token or code
IDENTITY__OIDCGETCLAIMSFROMUSERINFOENDPOINT: false
IDENTITY__OIDCSINGOUTREDIRECTURL: null
LETSENCRYPT_HOST: null
LETSENCRYPT_EMAIL: null
# LOGGING SETTINGS
LOGGING__LEVEL: INFORMATION # Trace, Debug, Information, Warning, Error, Fatal
LOGGING__HUMAN: false # Setting the flag to true, enables well formatteds json logs
LOGGING__COLORS: false # Set to true, to use colors
LOGGING__LOGREQUESTS: true # Set to false to disable logging of http requests
LOGGING__STOREENABLED: true # False to disable the log store
LOGGING__STORERETENTIONINDAYS: 90 # The number of days request log items will be stored
LOGGING__STACKDRIVER__ENABLED: false # True, to enable stackdriver integration
LOGGING__OTLP__ENABLED: false # True, to enable OpenTelemetry Protocol integration
LOGGING__OLTP__ENDPOINT: null # The endpoint to the agent
LOGGING__APPLICATIONINSIGHTS__ENABLED: false # True, to enable application insights integraon
LOGGING__APPLICATIONINSIGHTS__CONNECTIONSTRING: null # "instrumentationkey=keyvalue"
# Define the clustering type
ORLEANS__CLUSTERING: MongoDB # SUPPORTED: MongoDB, Development
ORLEANS__KUBERNETES: true # Tell Orleans it is running in kubernetes
# Define the type of the read store
STORE__MONGODB__CONTENTDATABASE: "SquidexContent"
# Assets
ASSETSTORE__TYPE: MongoDb
URLS__BASEURL: https://my.domain.com/ # Set the base url of your application, to generate correct urls in background process
URLS__ENFORCEHTTPS: true # Set it to true to redirect the user from http to https permanently
mongodb-replicaset:
enabled: true
replicas: 3
auth:
enabled: false
existingKeySecret: ""
existingAdminSecret: ""
existingMetricsSecret: ""
# adminUser: username
# adminPassword: password
# metricsUser: metrics
# metricsPassword: password
# key: keycontent
persistentVolume:
enabled: true
## mongodb-replicaset data Persistent Volume Storage Class
## If defined, storageClassName: <storageClass>
## If set to "-", storageClassName: "", which disables dynamic provisioning
## If undefined (the default) or set to null, no storageClassName spec is
## set, choosing the default provisioner. (gp2 on AWS, standard on
## GKE, AWS & OpenStack)
storageClassName: "csi-disk"
storageClass: "csi-disk"
accessModes:
- ReadWriteOnce
nodeSelector: {}
- [x] Self hosted with other version
Version: latest
- [x] Chrome (desktop)
The 2 nodes we are running are: 4 cores | 8 GB memory | 100Gb disks
I have managed to get a random online tutorial running, with 2 web apps using https and the same setup.
Thanks for the very nice application, which we choose over some others we tested. We like it a lot, and hope to get this wokring soon.
Thanks in advance for any help. We have been trying for weeks to get this running. Let me know if any more details are needed.
