I do have URLS__BASEURL: https://www.myurl.com/squidex in my values.yaml (which is why I am confused)
The value for ASSETSTORE__TYPE seems to be MongoDb
And URLS__BASEPATH? I am not sure right now to be honest. I have tested it a few times with IIS, but have forgotten what I configured
… I should document it.
I will write down 2 tasks:
- Check the helm chart again and make the necessary fixes:
- Permissions
- Mongo Configuration
- Test the path thing.
I am not sure where to look for URLS__BASEPATH.
kubectl logs deployment/squidex -n app
and
kubectl logs pod/squidex -n app
did not have such value.
Thanks Sebastian. It might be my “weird” url or the namespace I use, that is messing with it. Not sure.
Linsting a few notes of my settings:
Url is https://frontend.some.ip.numbers.here.nip.io/webapp3/
Namespace is “app”
The ingress controller is in namespace ingress
The ingress is in namespace app targeting service squidex (which is the name of the service within namespace app)
You can just add it to the Values.yaml.
Just tried adding URLS__BASEPATH and the url https://frontend.some.ip.numbers.here.nip.io/webapp3
It did not make a difference unfortunately
Posting logs for deployment, removed ip numbers.
This part might be of interest at it seems incomplete:
{"logLevel":"Information","message":"Now listening on: http://[::]:80","address":"http://[::]:80","timestamp":"2022-03-18T17:57:12Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"},"category":"Microsoft.Hosting.Lifetime"}
kubectl logs deploy/squidex -n app
{"logLevel":"Information","message":"Application started","environment":{"applicationname":"Squidex","aspnetcore_urls":"http://\u002B:80","aspnet_version":"5.0.0","assets:defaultpagesize":"200","assets:deletepermanent":"False","assets:deleterecursive":"True","assets:folderperapp":"False","assets:maxresults":"200","assets:maxsize":"5242880","assets:timeoutfind":"00:00:01","assets:timeoutquery":"00:00:05","assetstore:amazons3:accesskey":"\u003CMY_KEY\u003E","assetstore:amazons3:bucket":"squidex-test","assetstore:amazons3:bucketfolder":"squidex-assets","assetstore:amazons3:forcepathstyle":"False","assetstore:amazons3:regionname":"eu-central-1","assetstore:amazons3:secretkey":"\u003CMY_SECRET\u003E","assetstore:amazons3:serviceurl":"","assetstore:azureblob:connectionstring":"UseDevelopmentStorage=true","assetstore:azureblob:containername":"squidex-assets","assetstore:exposesourceurl":"False","assetstore:folder:path":"Assets","assetstore:ftp:password":"","assetstore:ftp:path":"Assets","assetstore:ftp:serverhost":"","assetstore:ftp:serverport":"21","assetstore:ftp:username":"","assetstore:googlecloud:bucket":"squidex-assets","assetstore:mongodb:bucket":"fs","assetstore:mongodb:configuration":"mongodb://squidex-mongodb-replicaset-0.squidex-mongodb-replicaset.app.svc.cluster.local,squidex-mongodb-replicaset-1.squidex-mongodb-replicaset.app.svc.cluster.local,squidex-mongodb-replicaset-2.squidex-mongodb-replicaset.app.svc.cluster.local","assetstore:mongodb:database":"SquidexAssets","assetstore:type":"MongoDb","caching:maxsurrogatekeyssize":"0","caching:replicated:enable":"True","caching:strongetag":"False","contentroot":"/app","contents:defaultpagesize":"200","contents:maxresults":"200","contents:timeoutfind":"00:00:01","contents:timeoutquery":"00:00:05","dotnet_running_in_container":"true","dotnet_version":"5.0.0","email:notifications:existinguserbody":"Dear User,\r\n\r\n$ASSIGNER_NAME ($ASSIGNER_EMAIL) has invited you to join App $APP_NAME at Squidex Headless CMS.\r\n\r\nLogin or reload the Management UI to see the App.\r\n\r\nThank you very much,\r\nThe Squidex Team\r\n\r\n\u003C\u003CStart now!\u003E\u003E [$UI_URL]","email:notifications:existingusersubject":"[Squidex CMS] You have been invited to join App $APP_NAME","email:notifications:newuserbody":"Welcome to Squidex\r\nDear User,\r\n\r\n$ASSIGNER_NAME ($ASSIGNER_EMAIL) has invited you to join Project (also called an App) $APP_NAME at Squidex Headless CMS. Login with your Github, Google or Microsoft credentials to create a new user account and start editing content now.\r\n\r\nThank you very much,\r\nThe Squidex Team\r\n\r\n\u003C\u003CStart now!\u003E\u003E [$UI_URL]","email:notifications:newusersubject":"You have been invited to join Project $APP_NAME at Squidex CMS","email:notifications:usagebody":"Dear User,\r\n\r\nYou you are about to reach your usage limit for App $APP_NAME at Squidex Headless CMS.\r\n\r\nYou have already used $API_CALLS of your monthy limit of $API_CALLS_LIMIT API calls.\r\n\r\nPlease check your clients or upgrade your plan!\r\n\r\n\u003C\u003CGo to Squidex!\u003E\u003E [$UI_URL]","email:notifications:usagesubject":"[Squidex CMS] You you are about to reach your usage limit for App $APP_NAME","email:smtp:enablessl":"True","email:smtp:password":"","email:smtp:port":"587","email:smtp:sender":"hello@squidex.io","email:smtp:server":"","email:smtp:username":"","eventpublishers:alltorabbitmq:configuration":"amqp://guest:guest@localhost/","eventpublishers:alltorabbitmq:enabled":"False","eventpublishers:alltorabbitmq:eventsfilter":".*","eventpublishers:alltorabbitmq:exchange":"squidex","eventpublishers:alltorabbitmq:type":"RabbitMq","eventstore:mongodb:configuration":"mongodb://squidex-mongodb-replicaset-0.squidex-mongodb-replicaset.app.svc.cluster.local,squidex-mongodb-replicaset-1.squidex-mongodb-replicaset.app.svc.cluster.local,squidex-mongodb-replicaset-2.squidex-mongodb-replicaset.app.svc.cluster.local","eventstore:mongodb:database":"Squidex","eventstore:type":"MongoDb","exposedconfiguration:version":"squidex:version","fulltext:elastic:configuration":"http://localhost:9200","fulltext:elastic:indexname":"squidex","fulltext:type":"default","healthz:gc:threshold":"4096","home":"/root","hostname":"squidex-86f9c7d5-bsldp","identity:adminclientid":"","identity:adminclientsecret":"","identity:adminemail":"rasmuslc@brain-plus.com","identity:adminpassword":"Represent123!","identity:adminrecreate":"true","identity:allowpasswordauth":"true","identity:githubclient":"\u003Cnil\u003E","identity:githubsecret":"\u003Cnil\u003E","identity:googleclient":"\u003Cnil\u003E","identity:googlesecret":"\u003Cnil\u003E","identity:lockautomatically":"false","identity:microsoftclient":"\u003Cnil\u003E","identity:microsoftsecret":"\u003Cnil\u003E","identity:microsofttenant":"\u003Cnil\u003E","identity:oidcauthority":"\u003Cnil\u003E","identity:oidcclient":"\u003Cnil\u003E","identity:oidcgetclaimsfromuserinfoendpoint":"false","identity:oidcmetadataaddress":"\u003Cnil\u003E","identity:oidcname":"\u003Cnil\u003E","identity:oidconsignoutredirecturl":"","identity:oidcresponsetype":"\u003Cnil\u003E","identity:oidcscopes":"[]","identity:oidcscopes:0":"email","identity:oidcsecret":"\u003Cnil\u003E","identity:oidcsingoutredirecturl":"\u003Cnil\u003E","identity:privacyurl":"https://squidex.io/privacy","identity:showpii":"true","kafka:bootstrapservers":"","kubernetes_port":"tcp://10.247.0.1:443","kubernetes_port_443_tcp":"tcp://10.247.0.1:443","kubernetes_port_443_tcp_addr":"10.247.0.1","kubernetes_port_443_tcp_port":"443","kubernetes_port_443_tcp_proto":"tcp","kubernetes_service_host":"10.247.0.1","kubernetes_service_port":"443","kubernetes_service_port_https":"443","languages:custom":"","letsencrypt_email":"rasmuslc@brain-plus.com","letsencrypt_host":"https://frontend.ip.numbers.nip.io/webapp3","logging:applicationinsights:connectionstring":"\u003Cnil\u003E","logging:applicationinsights:enabled":"false","logging:colors":"false","logging:human":"false","logging:level":"INFORMATION","logging:logrequests":"true","logging:oltp:endpoint":"\u003Cnil\u003E","logging:otlp:enabled":"false","logging:otlp:endpoint":"","logging:stackdriver:enabled":"false","logging:storeenabled":"true","logging:storeretentationindays":"90","logging:storeretentionindays":"90","mode:isreadonly":"False","news:appname":"squidex-website","news:clientid":"squidex-website:default","news:clientsecret":"QGgqxd7bDHBTEkpC6fj8sbdPWgZrPrPfr3xzb3LKoec=","notifo:apikey":"","notifo:apiurl":"https://app.notifo.io","notifo:appid":"","orleans:clustering":"MongoDB","orleans:gatewayport":"40000","orleans:ipaddress":"","orleans:kubernetes":"true","orleans:siloport":"11111","orleans_cluster_id":"squidex","orleans_service_id":"squidex-5.9.0","paas_pod_id":"c225ef32-9750-4725-914a-da8bcb5539f2","path":"/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin","plugins:0":"Squidex.Extensions.dll","pod_ip":"172.16.0.26","pod_name":"squidex-86f9c7d5-bsldp","pod_namespace":"app","rebuild:apps":"False","rebuild:assetfiles":"False","rebuild:assets":"False","rebuild:contents":"False","rebuild:indexes":"False","rebuild:rules":"False","rebuild:schemas":"False","robots:text":"User-agent: *\nAllow: /api/assets/*","rules:executiontimeoutinseconds":"10","running_in_container":"true","squidex_port":"tcp://10.247.171.106:80","squidex_port_80_tcp":"tcp://10.247.171.106:80","squidex_port_80_tcp_addr":"10.247.171.106","squidex_port_80_tcp_port":"80","squidex_port_80_tcp_proto":"tcp","squidex_service_host":"10.247.171.106","squidex_service_port":"80","squidex_service_port_http":"80","store:mongodb:configuration":"mongodb://squidex-mongodb-replicaset-0.squidex-mongodb-replicaset.app.svc.cluster.local,squidex-mongodb-replicaset-1.squidex-mongodb-replicaset.app.svc.cluster.local,squidex-mongodb-replicaset-2.squidex-mongodb-replicaset.app.svc.cluster.local","store:mongodb:contentdatabase":"SquidexContent","store:mongodb:database":"Squidex","store:type":"MongoDb","translations:deepl:authkey":"","translations:deepl:mapping:zh-cn":"zh-CN","translations:deepl:mapping:zh-tw":"zh-TW","translations:googlecloud:projectid":"","twitter:clientid":"QZhb3HQcGCvE6G8yNNP9ksNet","twitter:clientsecret":"Pdu9wdN72T33KJRFdFy1w4urBKDRzIyuKpc0OItQC2E616DuZD","ui:google:analyticsid":"UA-99989790-2","ui:hidedatebuttons":"False","ui:hidedatetimemodebutton":"False","ui:hidenews":"False","ui:hideonboarding":"False","ui:map:googlemaps:key":"AIzaSyB_Z8l3nwUxZhMJykiDUJy6bSHXXlwcYMg","ui:map:type":"OSM","ui:onlyadminscancreateapps":"False","ui:redirecttologin":"False","ui:referencesdropdownitemcount":"100","ui:regexsuggestions:email":"^[a-zA-Z0-9.!#$%\u0026\u2019*\u002B\\/=?^_\u0060{|}~-]\u002B@[a-zA-Z0-9-]\u002B(?:.[a-zA-Z0-9-]\u002B)*$","ui:regexsuggestions:phone":"^\\(*\\\u002B*[1-9]{0,3}\\)*-*[1-9]{0,3}[-. /]*\\(*[2-9]\\d{2}\\)*[-. /]*\\d{3}[-. /]*\\d{4} *e*x*t*\\.* *\\d{0,4}$","ui:regexsuggestions:slug":"^[a-z0-9]\u002B(\\-[a-z0-9]\u002B)*$","ui:regexsuggestions:url":"^(?:http(s)?:\\/\\/)?[\\w.-]\u002B(?:\\.[\\w\\.-]\u002B)\u002B[\\w\\-\\._~:\\/?#%[\\]@!\\$\u0026\u0027\\(\\)\\*\\\u002B,;=.]\u002B$","ui:showinfo":"False","urls":"http://\u002B:80","urls:basepath":"https://frontend.ip.numbers.nip.io/webapp3","urls:baseurl":"https://frontend.ip.numbers.nip.io/webapp3","urls:enableforwardheaders":"True","urls:enforcehost":"False","urls:enforcehttps":"false","version":"5.0.0","webapp1_svc_port":"tcp://10.247.201.77:80","webapp1_svc_port_80_tcp":"tcp://10.247.201.77:80","webapp1_svc_port_80_tcp_addr":"10.247.201.77","webapp1_svc_port_80_tcp_port":"80","webapp1_svc_port_80_tcp_proto":"tcp","webapp1_svc_service_host":"10.247.201.77","webapp1_svc_service_port":"80","webapp2_svc_port":"tcp://10.247.230.227:80","webapp2_svc_port_80_tcp":"tcp://10.247.230.227:80","webapp2_svc_port_80_tcp_addr":"10.247.230.227","webapp2_svc_port_80_tcp_port":"80","webapp2_svc_port_80_tcp_proto":"tcp","webapp2_svc_service_host":"10.247.230.227","webapp2_svc_service_port":"80"},"timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initialize":["ValidationInitializer","SerializationInitializer","LanguagesInitializer","MongoAssetFolderRepository","MongoAssetRepository","MongoContentRepository","MongoEventStore","MongoGridFsAssetStore","MongoHistoryEventRepository","MongoMigrationStatus","MongoRequestLogRepository","MongoRoleStore","MongoRuleEventRepository","MongoSchemasHash","MongoTextIndex","MongoTextIndexerState","MongoUsageRepository","MongoUserStore","TokenStoreInitializer","CreateAdminInitializer"],"timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"ValidationInitializer","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"SerializationInitializer","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"LanguagesInitializer","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"MongoAssetFolderRepository","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"MongoAssetRepository","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"MongoContentRepository","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"MongoEventStore","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"MongoGridFsAssetStore","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"MongoHistoryEventRepository","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"MongoMigrationStatus","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"MongoRequestLogRepository","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"MongoRoleStore","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"MongoRuleEventRepository","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"MongoSchemasHash","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"MongoTextIndex","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"MongoTextIndexerState","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"MongoUsageRepository","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"MongoUserStore","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"TokenStoreInitializer","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","initializedSystem":"CreateAdminInitializer","timestamp":"2022-03-18T17:57:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","start":["IContentSchedulerGrain","IEventConsumerManagerGrain","IRuleDequeuerGrain","IUsageTrackerGrain"],"timestamp":"2022-03-18T17:57:11Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","startedSystem":"IContentSchedulerGrain","timestamp":"2022-03-18T17:57:11Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","startedSystem":"IEventConsumerManagerGrain","timestamp":"2022-03-18T17:57:11Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","startedSystem":"IRuleDequeuerGrain","timestamp":"2022-03-18T17:57:11Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","startedSystem":"IUsageTrackerGrain","timestamp":"2022-03-18T17:57:11Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","action":"pluginsLoaded","status":"Completed","errors":[],"plugins":["Squidex.Extensions.Validation.CompositeUniqueValidatorPlugin","Squidex.Extensions.Samples.Middleware.TemplatePlugin","Squidex.Extensions.Samples.AssetStore.MemoryAssetStorePlugin","Squidex.Extensions.Assets.Azure.AzureMetadataSourcePlugin","Squidex.Extensions.APM.Stackdriver.StackdriverPlugin","Squidex.Extensions.APM.Datadog.OtlpPlugin","Squidex.Extensions.APM.ApplicationInsights.ApplicationInsightsPlugin","Squidex.Extensions.Actions.Webhook.WebhookPlugin","Squidex.Extensions.Actions.Twitter.TwitterPlugin","Squidex.Extensions.Actions.Slack.SlackPlugin","Squidex.Extensions.Actions.SignalR.SignalRPlugin","Squidex.Extensions.Actions.Script.ScriptPlugin","Squidex.Extensions.Actions.Prerender.PrerenderPlugin","Squidex.Extensions.Actions.Notification.NotificationPlugin","Squidex.Extensions.Actions.Medium.MediumPlugin","Squidex.Extensions.Actions.Kafka.KafkaPlugin","Squidex.Extensions.Actions.Fastly.FastlyPlugin","Squidex.Extensions.Actions.Email.EmailPlugin","Squidex.Extensions.Actions.ElasticSearch.ElasticSearchPlugin","Squidex.Extensions.Actions.Discourse.DiscoursePlugin","Squidex.Extensions.Actions.CreateContent.CreateContentPlugin","Squidex.Extensions.Actions.Comment.CommentPlugin","Squidex.Extensions.Actions.AzureQueue.AzureQueuePlugin","Squidex.Extensions.Actions.Algolia.AlgoliaPlugin"],"timestamp":"2022-03-18T17:57:12Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"}}
{"logLevel":"Information","message":"Application started. Press Ctrl\u002BC to shut down.","timestamp":"2022-03-18T17:57:12Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"},"category":"Microsoft.Hosting.Lifetime"}
{"logLevel":"Information","message":"Hosting environment: Production","envName":"Production","timestamp":"2022-03-18T17:57:12Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"},"category":"Microsoft.Hosting.Lifetime"}
{"logLevel":"Information","message":"Content root path: /app","contentRoot":"/app","timestamp":"2022-03-18T17:57:12Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"},"category":"Microsoft.Hosting.Lifetime"}
{"logLevel":"Warning","message":"Grain *cli/b643be95 owned by S172.16.0.26:11111:385322229 was found in the cache of S172.16.0.26:11111:385322229","eventId":{"id":100185},"grain":"*cli/b643be95","owner":"S172.16.0.26:11111:385322229","owner":"S172.16.0.26:11111:385322229","timestamp":"2022-03-18T18:03:10Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"12b0a7fa-edc8-4284-bc82-7345f8a7c1ff"},"category":"Runtime.GrainDirectory.AdaptiveDirectoryCacheMaintainer"}
URLS__BASEPATH should be just the path, like “/webapp3” I think.
Sounds reasonable, however changing it to /webapp3 did not help
So the generated URLs are still wrong? I will check it this weekend and give you an answer at monday.
Yes, apparently they are still the same. All referencing the baseurl not the path. :-/
Thank you, have a great weekend.
I have updated a new version of the helm chart.
Thanks Sebastian.
I just got a chance to try it. The pods seems to start nicely, and I can access the website via subdomain (have not tried a path url yet). The roles and database connections work out of the box.
However when pressing login, I get the pop up and it says:
error:invalid_request
error_description:The specified 'redirect_uri' is not valid for this client application.
error_uri:https://documentation.openiddict.com/errors/ID2043
Still testing and trying to figure out what it needs now.
Can you check the logs? You should see the details there. Very likely still a problem with the base url.
Log is to big to post, and uploading the txt file is not allowed.
Will try and post in several replies. Part 1
EDIT deleted large text here
part 2
part 3
No Human being can read that … why do you not upload it somwhere?
it doe no look complete. Afaik there should be an output where the actual redirect uri and the expected redirect uri is shown.
Sorry, I forgot to reproduce before getting the logs. Here is the events from clicking the login button.
{"logLevel":"Information","filters":{"costs":0},"elapsedRequestMs":53,"timestamp":"2022-03-21T15:06:11Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"05eebb1a-45bc-4011-9cee-3823717a9069"},"web":{"requestId":"00-841567bd0a2db0f9ad11ea2d4d91b6e2-805640a8b41727c2-01","requestPath":"/build/index.html","requestMethod":"GET"}}
{"logLevel":"Information","filters":{"costs":0},"elapsedRequestMs":11,"timestamp":"2022-03-21T15:09:58Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"05eebb1a-45bc-4011-9cee-3823717a9069"},"web":{"requestId":"00-6b52ecf414f8e180107ceee448e352d6-4efd67760552673c-01","requestPath":"/build/index.html","requestMethod":"GET"}}
{"logLevel":"Information","filters":{"costs":0},"elapsedRequestMs":178,"timestamp":"2022-03-21T15:10:01Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"05eebb1a-45bc-4011-9cee-3823717a9069"},"web":{"requestId":"00-d9091568c252daf77c8f655ac4ed205e-e179ea2b3c5f4997-01","requestPath":"/identity-server/.well-known/openid-configuration","requestMethod":"GET"}}
{"logLevel":"Information","filters":{"costs":0},"elapsedRequestMs":72,"timestamp":"2022-03-21T15:10:01Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"05eebb1a-45bc-4011-9cee-3823717a9069"},"web":{"requestId":"00-1411bf67f070e42b3d6bcef5528460b7-758ab2c43925a9d4-01","requestPath":"/identity-server/connect/authorize","requestMethod":"GET"}}
{"logLevel":"Information","filters":{"costs":0},"elapsedRequestMs":5,"timestamp":"2022-03-21T15:20:12Z","app":{"name":"Squidex","version":"5.9.0.0","sessionId":"05eebb1a-45bc-4011-9cee-3823717a9069"},"web":{"requestId":"00-956a6714a735afe6c1801c3391df0ce1-47dc914b825d86cc-01","requestPath":"/identity-server/connect/authorize","requestMethod":"GET"}}
