Squidex content stuck in MongoDb and is not shown on UI.
Squdiex content is marked as deleted and continue to be stored in MongoDb.
Squidex content stuck in MongoDb after Squidex App deletion and recreation with same name.
I’m confussed what happens in Squidex’s MongoDb.
I want to find a and read Squidex Content records [by a schema] in MongoDb.
I want to understand can I safe delete all Squidex secondary content from MongoDb manually.
And what is safe to delete at all.
Out of scope
Find and delete schemas from MongoDB.
- [x] Self hosted with docker
Version:7.0+
Main topic question - interfering Squidex MongoDB, in order to fix and debug issues that are not fixeble from outside anymore by API/Squidex Library/Squidex UI. And I believe only direct manual deletion from DB can help me.
Thanks ahead.
