Hi @Sebastian ,
I want to push the referenced item field value to elastic search using the rules through the scripts. I found **getReference(id, callback) ** method mentioned in docs.
Let me know Is it possible using above method then how ? or any other way to achieve this.
Regards,
Rakesh Kanani
              What do you use to format your rule? Scripts or Liquid?
              Hi @Sebastian,
I am using  âScriptsâ format for rule.
              You have to do somehing like this
getReference(event.data.author.iv[0], function (references) {
	var author = references[0];
	var jsonObject = {
		title: event.data.title.iv,
		text: event.data.text.iv,
		authorName: author.data.name.iv
	var json = JSON.stringify(jsonObject);
	complete(json);
Btw: You can now make the changes in the rule and run the simulator without saving it. So you can play around with that.
See: Asset Id to URL in webhook
              Thanks @Sebastian.
This is working fine.
I have a 1: M relationship in one of the table, then how can we loop in the âgetReferencesâ method.
              Just loop over them
getReferences(event.data.author.iv, function (references) {
	var jsonObject = {
		authors: []
	for (var author of references) {
		jsonObject.authors.push({
	complete(json);
              Thank you so much @Sebastian, for your prompt response! I appreciate you getting this information to me so quickly.
