According to Orlean’s doc here https://dotnet.github.io/orleans/docs/deployment/kubernetes.html
There is a Microsoft.Orleans.Hosting.Kubernetes package. I wonder if you are aware of that and if you want to have the same deployment setup like the doc says.
Thanks!
I have seen it a while ago, but I havent had the time yet to have a closer look. It is a lot of work
Integration (should be simple)
Testing
Documentation
But PRs are very welcome
Cool, I might work on it once we get some progress on our project. Currently I still have some problems with Squidex’ authentication. I haven’t pin point the issue yet, but I think it has something to do with the cookie. Once I figure out, I will report it here.
Just ask. Usually I have heard the questions before. The main issue with authentication is that the baseUrl setting does not fit to to the actual URL.
no, I know that one already. I can login and use almost everything except /orleans
I put the question here so we can track it properly.
[X] Bug report
[ ] Performance issue
can’t access
[image]
[X] Self hosted with docker
[ ] Self hosted with IIS
[ ] Self hosted with other version
[ ] Cloud version
Version: latest commit
[X] Chrome (desktop)
[ ] Chrome (Android)
[ ] Chrome (iOS)
[ ] Firefox
[ ] Safari (deskto…
I just discovered if I don’t assign more than one core to the pod. It throws a ServerGC warning like
ServerGC only kicks in on multi-core systems (settings enabling ServerGC have no effect on single-core machines)
I think we can document it at https://docs.squidex.io/01-getting-started/installation/platforms/install-on-kubernetes
Also thanks for adding this Microsoft.Orleans.Hosting.Kubernetes package. It works perfectly.
You could provide a PR for the docs.
I also asked my CI expert yesterday to upgrade the helm charts with the kubernetes package stuff.
