- [X] Bug report
can’t access
- [X] Self hosted with docker
Version: latest commit
- [X] Chrome (desktop)
I moved the discuss here to fit the topic properly.
I think the problem is there is no cookie or somehow I can’t get cookie set properly.
I can see bear token so api area works fine with angular. I can login do everything just fine except the cluster area, which load an iframe and call /orleans directly.
And it will reject the call because there is no cookie and send it back to /orleans/signin-internal
this is also odd as well. I was expecting it should go to /signin-internal directly. I wonder if it is because of “app.Map(Constants.PrefixOrleans, orleansApp =>”
I will keep digging on this one. I have used identity server 4 before but I didn’t use it with cookie, so I am trying to figure how it should work properly.
I do not have this problem. Cannot reproduce it.
It is ok. I will keep digging. Not sure if it is a bug or some setting I mess up. I will keep you post if I find anything.
Here is the error log
“logLevel”: “Error”,
“message”: “An unexpected exception has occurred.”,
“timestamp”: “2021-06-29T19:14:01Z”,
“app”: {
“name”: “Squidex”,
“version”: “1.0.0.0”,
“sessionId”: “f27ad77e-4a02-4310-91ce-e72685fb22f6”
“web”: {
“requestId”: “00-4241f3bf56a1194097c43af23e667ed6-e6c6a9b8decd1b4f-00”,
“requestPath”: “/orleans”,
“requestMethod”: “GET”
“exception”: {
“type”: “System.InvalidOperationException”,
“message”: “IDX20803: Unable to obtain configuration from: \u0027https://localhost:5001/identity-server/.well-known/openid-configuration\u0027.”,
“stackTrace”: " at Microsoft.IdentityModel.Protocols.ConfigurationManager\u00601.GetConfigurationAsync(CancellationToken cancel)\r\n at Microsoft.AspNetCore.Authentication.OpenIdConnect.OpenIdConnectHandler.HandleChallengeAsyncInternal(AuthenticationProperties properties)\r\n at Microsoft.AspNetCore.Authentication.OpenIdConnect.OpenIdConnectHandler.HandleChallengeAsync(AuthenticationProperties properties)\r\n at Microsoft.AspNetCore.Authentication.AuthenticationHandler\u00601.ChallengeAsync(AuthenticationProperties properties)\r\n at Microsoft.AspNetCore.Authentication.AuthenticationService.ChallengeAsync(HttpContext context, String scheme, AuthenticationProperties properties)\r\n at Squidex.Areas.OrleansDashboard.Middlewares.OrleansDashboardAuthenticationMiddleware.InvokeAsync(HttpContext context) in E:\repo\oss\squidex\backend\src\Squidex\Areas\OrleansDashboard\Middlewares\OrleansDashboardAuthenticationMiddleware.cs:line 44\r\n at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)\r\n at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)\r\n at Microsoft.AspNetCore.Builder.Extensions.MapMiddleware.Invoke(HttpContext context)\r\n at Microsoft.AspNetCore.Builder.Extensions.MapMiddleware.Invoke(HttpContext context)\r\n at Microsoft.AspNetCore.Builder.Extensions.MapMiddleware.Invoke(HttpContext context)\r\n at Squidex.Web.Pipeline.LocalCacheMiddleware.InvokeAsync(HttpContext context, ILocalCache localCache) in E:\repo\oss\squidex\backend\src\Squidex.Web\Pipeline\LocalCacheMiddleware.cs:line 27\r\n at Microsoft.AspNetCore.Localization.RequestLocalizationMiddleware.Invoke(HttpContext context)\r\n at Squidex.Web.Pipeline.UsageMiddleware.InvokeAsync(HttpContext context, RequestDelegate next) in E:\repo\oss\squidex\backend\src\Squidex.Web\Pipeline\UsageMiddleware.cs:line 41\r\n at Squidex.Web.Pipeline.UsageMiddleware.InvokeAsync(HttpContext context, RequestDelegate next) in E:\repo\oss\squidex\backend\src\Squidex.Web\Pipeline\UsageMiddleware.cs:line 85\r\n at Microsoft.AspNetCore.Builder.UseMiddlewareExtensions.\u003C\u003Ec__DisplayClass6_1.\u003C\u003CUseMiddlewareInterface\u003Eb__1\u003Ed.MoveNext()\r\n— End of stack trace from previous location —\r\n at Squidex.Web.Pipeline.RequestLogPerformanceMiddleware.InvokeAsync(HttpContext context, ISemanticLog log) in E:\repo\oss\squidex\backend\src\Squidex.Web\Pipeline\RequestLogPerformanceMiddleware.cs:line 49\r\n at Squidex.Web.Pipeline.RequestExceptionMiddleware.InvokeAsync(HttpContext context, IActionResultExecutor\u00601 writer, ISemanticLog log) in E:\repo\oss\squidex\backend\src\Squidex.Web\Pipeline\RequestExceptionMiddleware.cs:line 42"
I think it is possible that it was caused by SSL, I am going to test that later
You are right. It is not a bug. It is caused by SSL. I didn’t install certificate locally. In case anyone else has the same issue, to run this locally, you have to generate / install the certificate from dev folder.
I have the same issue when I run it on k8s locally. I think they are caused by the same issue.
It turns out it is a different issue in k8s. In case anyone else might have the same issue.
It is possible that the header is too big.
After setting it like this, everything works now
nginx.ingress.kubernetes.io/proxy-buffer-size: 16k
