No, not the only issue. I also found an issue on my side. But even if I solve mine, it would be a problem.
What was the issue ?
I have a special type of FormArrays:
This takes a template (a factory how to construct the items) and when you setValue it calls the template to create the item forms:
I have forgotten not to set āemitEvent: falseā when adding items here, causing unnecessary updates about intermediate values.
So if the initial value was [] and you have sent [{}, {}, {}] to Squidex, the iframe control was receiving the following values:
[{}] // Previous: [{}, {}, {}]
[{}, {}] // Previous: [{}]
[{}, {}, {}] // Previous: [{}, {}]
And of course each of them was different to the previous value.
Makes sense. I did receive incremental item length for array in the valueChanged event.
Could you create a bug report for the issue?
Okay. I will create one.
No, sorryā¦but you can install the latest dev version.
Is it fixed already ?
Yes, you can install latest dev version.
Great !! Can you let me know the docker image tag ?
Sureā¦it is dev-7438
Hello - Will the fix be available as part of 7.4.0 release ?
Yes, I will prepare it tomorrow, I think. But it is not a promise.
Hello - Any progress on 7.4 release ?
@Sebastian - I see that the valueChanged event is getting fired in the latest 7.4 release. In my array there are 425 items and when I change their position using custom UI, I see valueChanged getting fired a minimum of three times.
Can you please double check ? Iām checking on my side to make sure that Iām indeed using 7.4 release .
Can you provide me your sample / custom editor again?
I will message you the drive link to the app.
