I’m about to deploy my app live and I’m currently configuring my client under Settings → Security → Clients and I was wondering how I should handle the situation when the token expires?
I’m in particular referring to the following text in the “Connect” dialog:
Tokens usally expire after 30days, but you can request multiple tokens.
If I enable “Allow anonymous access.” for my client everything will obviously work but I want to be able to secure this client as much as possible.
Can you please advice how I can go about it?
Btw, the following is how I’m currently using the GraphQL endpoint in my Next.js app:
export async function fetchAllProductsTotal(): Promise<number> {
  try {
    const response = await fetch(`${process.env.GRAPHQL_ENDPOINT}`, {
      method: "POST",
      headers: {
        "Content-Type": "application/json",
      body: JSON.stringify({
        query: queryAllProductsTotal,
    if (!response.ok) {
      throw new Error(
        `Failed to fetch all products total from Squidex. Status: ${response.status} ${response.statusText}`,
    const result = await response.json();
    if (!result.data || !result.data.queryProductContentsWithTotal) {
      console.error("No total products data found in Squidex.");
      return 0;
    return result.data.queryProductContentsWithTotal.total;
  } catch (error) {
    console.error(error);
    return 0;
I could add the Authorization: Bearer header to my POST request but it would still fail after 30 days?
              You could just use the node SDK? GitHub - Squidex/sdk-node: Node.js SDK for the Squidex API
If this is not possible, I would implement the following logic:
- Implement a general middleware or fetch function
- If there is no token in the cache, fetch the token first, then make the actual request.
- Store the token in the cache usign the lifetime of the response object.
- If the actual request fails, get a new token and try again.
              Thanks for the quick reply.
I looked at the SDK and it looks like something that would probably work but I would have to rewrite tons of code and the testing that comes with that so today this is not an option. Maybe in the future. Also I noticed the SDK is still in RC?
Regarding the second option:
Implement a general middleware or fetch function ← Next.js has some middleware stuff in it that you could probably use. But this sounds like the most complicated approach? A generic fetch function might work.
If there is no token in the cache, fetch the token first, then make the actual request. ← what do you mean by “fetch the token first”? The first thing that comes to mind is the “Get a token using curl” in Client section in Squidex:
$ curl
-X POST 'https://cloud.squidex.io/identity-server/connect/token'
-H 'Content-Type: application/x-www-form-urlencoded'
-d 'grant_type=client_credentials&
client_id=xyz:default
client_secret=blah
scope=squidex-api'
is this what you are referring to?
Update 1: Now that I come to think of it; wouldn’t it be easier if the token is generated once, with no expiration, and then, if needed, one could manually generate a new token. This is how most systems that use some sort of secret key/sensitive credentials work today. I think that in the end the responsibility is on the developer and not the system whether or not the secret is handled appropriately. So I guees what I’m trying to say is that I think that the bearer token for a squidex client should not expire and if you need a new one for some reason you should be able to manually generate a new one from within the squidex UI (like other SaaS dashboards do it). Oh, and one last thing. There is usually a “dev API secrets/keys” and a “prod API secrets/keys” in these systems so that it becomes really obvious which to use and when.
Sebastian, do you think this would be a major thing? Hard to implement? A lot of rework in the UI etc I’d imagine?
