Currently the Header “X-Resolve-Urls”: “*” can be used to resolve the complete resource Url of a referenced asset, this is working fine.
I am having a schema “Collection” that can reference different other schemas (“Item1Schema”, “Item2Schema”). When retrieving the content of type “Collection” (via Rest-Api) I only get a list of Guids and I do not know which (“Item1Schema”, “Item2Schema”) endpoint I should contact with these Guids in order to retrieve these referenced items.
Is it possible to get the resolved Urls also for fields of type Reference?
Do you have any idea/best practice?
- Create schemas: Collection, Item1Schema, Item2Schema
- Create a Multi-References field named “Items” at the Collection schema
- Assign Item1Schema, Item2Schema to the possible Schemas of “Items”
- [x] Self hosted with docker
- [x] Chrome (desktop)
Thank you for your good work and this awesome CMS.
