Workflow configuration
i am probably missing some configurtions so I hope you can help me.
I have created a custom role “co-editor” with these permissions:
contents..read
contents.
.create
contents..update.partial
assets.
contents.*.version.create
I noticed that the user with role “co-editor” is able to make a content published or change the status from ready to publish.
Furthetmore, in workflow configuration (settings/workflows) I select and save a specif role for the transition from ready --> publish but the role disappear from the box. Could you be so kind to explay me how to configurate the “when” box and “for” box (where I selected the role editor without success).
Thanks,
Salvo
  • [ ] Checked the logs and have provided the logs if I found something suspicious there
  • [ ] Bug report
  • [ ] Self hosted with docker
  • [ ] Chrome (desktop)
