- Bug report <!-- Please search the support forum for a similar before submitting –
I created one Multiple contents (Schema A) schema and one Single content (Schema B) schema, then I tried to create reference to field inside Schema A to reference content from Schema B, but in the drop down I cannot find Schema B
I can add reference field inside Schema A and add reference to Schema B
- Create multiple contents Schema A
- Create single content Schema B
 3 For Schema A add reference field with name ‘common’ in Validation tab try to choose Schema B
App Name: AppName
- Self hosted with docker
- Self hosted with IIS
- Cloud version
Version: I weak ago installed
- Chrome (desktop)
- Chrome (Android)
- Chrome (iOS)
- Firefox
- Safari (desktop)
- Safari (iOS)
- IE
- Edge
No
