Where are we using squidex/backend/i18n project in the src code?
Hi
I have a small doubt regarding the usage of ‘squidex/backend/i18n’ project. I haven’t found any reference of this project in ‘squidex/backend/src’. Can you help me with its reference and usage?
Thanks.
This are just the source files:
Backend
The generator in the project creates the resx files:
Fontend
Development Time
The resources are loaded directly from this folder:
Production
The translations is injected into the HTML and loaded as global variable:
Thanks for the explanation.
I have forgotten to mention that it is also documented here: https://docs.squidex.io/01-getting-started/contributing-and-developing/translating
