I have a dedicated server and an on-premises squidex setup. When I set baseURL to http in app settings, “http://domainname/identity-server/.well-known/openid-configuration” returns http 200 ok and json configuration properly. When I configure the appsettings as https, “https://domainname/identity-server/.well-known/openid-configuration” address returns 404 not found page with 304 http code. Because of this, the user login screen does not open.
The application is hosted on IIS. No mistakes etc. is it available?
Thank you.
