Webhooks => X-Signature & Secret matching
We can’t manage to match the X-Signature on our side.
Here is our method :
[HttpPost]
[Route(“settings/refresh”)]
public async Task RefreshSettingsAsync([FromHeader(Name = “X-Signature”)] string XSignature) {
        if (!XSignature.IsNotEmpty())
            return BadRequest("X-Signature missing");
        using (var reader = new StreamReader(Request.Body))
            var body = reader.ReadToEnd();
            string hashedSecret = (AppSettings.Value.Data.AppSecretKey + body).Sha256Base64();
            if (hashedSecret != XSignature)
                return BadRequest("Secrets are not matching");
        applicationLifetime.StopApplication();
        return Ok("App was restarted...");
wich always returns hashedSecret != XSignature
How is computed the has on your side ?
Do you confirm : Base64(Sha256(RequestBody + Secret)) ?
Any help ?
[ x] Bug report
[ ] Performance issue
  • [ ] Self hosted with version docker
  • [x ] Cloud version
  • [ ] Chrome (desktop)
What I see is that you changed the order of the secret and the body.
This is my implementation:
Can you share your Sha256Base64 method ?
My method is exactly the same as yours. I even made a test with a copy from your code. I still have different hashs…
That’s weird !
One thing that was definitely different is:
vs
$"{requestBody}{action.SharedSecret}".Sha256Base64(),
so hash and body are concatenated in different orders.
Solved !
String + string !== $(string string)
Good to know.
Really? Is it not the order that is the problem? Have you tested
(body + AppSettings.Value.Data.AppSecretKey).Sha256Base64()
