Webhooks seem to have changed to GET instead of POST. Was this intended?
Am I missing an new setting maybe?
Which version are you using, I am not aware of any change. In the code I still see a POST.
Btw: which version are you talking about? Self hosted? Cloud?
I tested it and it works. But my assumption is that you have a permanent redirect, e.g. when you make a POST call to a http:// endpoint that redirects to https:// … I tested it
Webhook to https://squidex.io works fine.
Webhook to http://squidex.io makes a redirect.
Thanks for your reply. Changed http to https and works now.
We were using the cloud version btw. A while ago we forced our websites to https on Azure. And apparently since that change we had to update the webhook url.
My bad
