- Bug report
- Performance issue
I created webhook rules for GraphQL mutation, in response getting below error. I checked rules log it shows status success. But it’s not created record and give below error in response.
{“errors”:[{“message”:“Error in $: Failed reading: not a valid json value at ‘mutationMyMutation{’”,“extensions”:{“path”:“$”,“code”:“invalid-json”}}]}
Same data I tried with postman and it working as expected.
It should create record & return create record data in json.
- Self hosted with docker
- Self hosted with IIS
- Cloud version
- Chrome (desktop)
- Chrome (Android)
- Chrome (iOS)
- Firefox
- Safari (desktop)
- Safari (iOS)
- IE
- Edge
If you want to refer the configuration.
appname: Map
rule name is: hasura-create-record
