Hi Sebastian!
We are planning to upgrade our self-hosted instance of Squidex from version “dev-5392” to the latest stable version (“7.5.0”). We have referred to the instructions provided in https://docs.squidex.io/02-documentation/concepts/migrations, but we are unsure whether we need to follow a specific upgrade path.
To test the upgrade process, we have applied the following upgrades in a testing env, and everything seems to be working correctly:
- Current version: “dev-5392”
- Upgrade to: “5.9.0”
- Upgrade to: “6.0.1”
- Upgrade to: “6.14.0”
- Upgrade to: “7.0.3”
- Upgrade to: “7.5.0”
Can we proceed with this sequence? Or do we need to add or remove any versions?
Thank you in advance.
