- [ x] Read the following guideline: https://docs.squidex.io/01-getting-started/installation/troubleshooting-and-support. I understand that my support request might get deleted if I do not follow the guideline.
- [x ] Documentation issue or request
Performing an app restore on version 6.3.0 using a backup that was create from 6.3.0 results in errors.
First: If the system user exists (i.e. the admin user defined by IDENTITY__ADMINEMAIL), attempting to restore an app results in the following error stack:
2021-12-28 14:20:21"logLevel": “Warning”,
2021-12-28 14:20:21"message": “User validation failed: DuplicateUserName.”,
2021-12-28 14:20:21"eventId": {
2021-12-28 14:20:21"id": 13
2021-12-28 14:20:21},
2021-12-28 14:20:21"errors": “DuplicateUserName”,
2021-12-28 14:20:21"timestamp": “2021-12-28T20:20:21Z”,
2021-12-28 14:20:21"app": {
2021-12-28 14:20:21"name": “Squidex”,
2021-12-28 14:20:21"version": “6.3.0.0”,
2021-12-28 14:20:21"sessionId": “4999391a-6d97-4725-9db4-11111111111”
2021-12-28 14:20:21"category": “Microsoft.AspNetCore.Identity.UserManager”
2021-12-28 14:20:21{
2021-12-28 14:20:21"logLevel": “Error”,
2021-12-28 14:20:21"action": “IdentityOperation”,
2021-12-28 14:20:21"status": “Failed”,
2021-12-28 14:20:21"message": “DuplicateUserName: Username \u0027[the identity email]\u0027 is already taken.\n”,
2021-12-28 12:46:09{
2021-12-28 12:46:09"logLevel": “Warning”,
2021-12-28 12:46:09"message": “CleanupDefunctSiloEntries operation is not supported by the current implementation of IMembershipTable. Disabling the timer now.”,
2021-12-28 12:46:09"eventId": {
2021-12-28 12:46:09"id": 100662
2021-12-28 12:46:09},
2021-12-28 12:46:09"timestamp": “2021-12-28T18:46:09Z”,
2021-12-28 12:46:09"app": {
2021-12-28 12:46:09"name": “Squidex”,
2021-12-28 12:46:09"version": “6.3.0.0”,
2021-12-28 12:46:09"sessionId": “4999391a-6d97-4725-9db4-11111111111”
2021-12-28 12:46:09"category": “Orleans.Runtime.MembershipService.MembershipTableCleanupAgent”
Second attempt: Let’s create a new container with a different admin email identity and try the restore again.
2021-12-28 14:48:11"sessionId": "7799ebe3-16db-4f2d-8d27-11111111111"
2021-12-28 14:48:11},
2021-12-28 14:48:11"exception": {
2021-12-28 14:48:11"type": "System.InvalidOperationException",
2021-12-28 14:48:11"message": "Error rate of 0 is above threshold 0.",
2021-12-28 14:48:11"stackTrace": " at Squidex.Infrastructure.Commands.Rebuilder.InsertManyAsync[T,TState](IAsyncEnumerable\u00601 source, Int32 batchSize, Double errorThreshold,
CancellationToken ct) in /src/src/Squidex.Infrastructure/Commands/Rebuilder.cs:line 177\n at Squidex.Infrastructure.Commands.Rebuilder.InsertManyAsync[T,TState](IEnumerable\u00601 source,
Int32 batchSize, Double errorThreshold, CancellationToken ct) in /src/src/Squidex.Infrastructure/Commands/Rebuilder.cs:line 87\n at
Squidex.Domain.Apps.Entities.Assets.BackupAssets.RestoreAsync(RestoreContext context, CancellationToken ct) in /src/src/Squidex.Domain.Apps.Entities/Assets/BackupAssets.cs:line 111\n at
Squidex.Domain.Apps.Entities.Backup.RestoreGrain.ProcessAsync() in /src/src/Squidex.Domain.Apps.Entities/Backup/RestoreGrain.cs:line 173"
2021-12-28 14:48:11{
2021-12-28 14:48:11"logLevel": "Error",
2021-12-28 14:48:11"action": "restore",
2021-12-28 14:48:11"status": "failed",
2021-12-28 14:48:11"operationId": "1ec63891-b425-4afb-b88d-35042dee4465",
2021-12-28 14:48:11"url": "https://[my s3 bucket URL]",
2021-12-28 14:48:11"timestamp": "2021-12-28T20:48:11Z",
2021-12-28 14:48:11"app": {
2021-12-28 14:48:11"name": "Squidex",
2021-12-28 14:48:11"version": "6.3.0.0",
2021-12-28 14:33:54{
2021-12-28 14:33:54"logLevel": "Warning",
2021-12-28 14:33:54"message": "CleanupDefunctSiloEntries operation is not supported by the current implementation of IMembershipTable. Disabling the timer now.",
2021-12-28 14:33:54"eventId": {
2021-12-28 14:33:54"id": 100662
2021-12-28 14:33:54},
2021-12-28 14:33:54"timestamp": "2021-12-28T20:33:54Z",
2021-12-28 14:33:54"app": {
2021-12-28 14:33:54"name": "Squidex",
2021-12-28 14:33:54"version": "6.3.0.0",
2021-12-28 14:33:54"sessionId": "7799ebe3-16db-4f2d-8d27-11111111111"
2021-12-28 14:33:54"category": "Orleans.Runtime.MembershipService.MembershipTableCleanupAgent"
I can restore any app backup without having to worry about user identity conflicts.
Not sure even what the issue is with the second error.
- [x ] Self hosted with docker
Version: 5.4.0
- [x ] Chrome (desktop)
Need to upgrade from 5.4.0 to 6.3.0 and migrate assets from Mongo to S3 and use ASSETS__FOLDERPERAPP = true
We cannot perform in-place upgrade of the environments because we need to be able to perform QA on the new environment before upgrading prod. So, we took the route of creating parallel Squidex docker deployments and Mongo instances.
Basic steps were:
- Create parallel 5.4.0 docker deployment. Set the new docker instance to use S3 storage. (Can’t use folderperapp yet, so just set it to false)
- Create backup (backup1) from original docker deployment.
- Restore this backup (backup1) to new docker deployment (results in a working install with S3 storage)
- Create another backup (backup2) just in case)
- Update the new deployment to use 6.3.0 (leaving folderperapp as false still)
- At this point the app is working, but the assets are in the root of the S3 bucket/squidex_assets/ folder. I want them in separate folders.
- Create another backup (backup3) and download it.
- Delete the app. (I noticed that the assets were not deleted)…so I manually deleted the /squidex_assets/ folder in S3.
- Update the new deployment and set “ASSETS_FOLDERPERAPP” = true
- Attempt to restore the app.
- Fails with Duplicate user error.
- Delete the app again.
- Update the new deployment and create a new admin user.
- Log in and delete all system users (except the new admin user).
- Am faced with the second error stack above.
Not sure how to proceed at this point.
Thank you.
