- Bug report
- Performance issue
Hi, I am using c#.
When I try to update content by schema id I get this error: “Validation error: showAfter: Not a known field., publicationListType: Not a known field., publicationItemType: Not a known field., imagePublicationItemMob: Not a known field., imagePublicationItem: Not a known field., imagePublicationListMob: Not a known field., imagePublicationList: Not a known field., imageLatterMob: Not a known field., imageLatter: Not a known field., imageMiddleMob: Not a known field., imageMiddle: Not a known field., imageNewsMob: Not a known field., imageNews: Not a known field., imageMainMob: Not a known field., imageMain: Not a known field., position: Not a known field., name: Not a known field., viewed: Not a known field., sort: Not a known field., url: Not a known field., dateEnd: Not a known field., dateStart: Not a known field.”
Though var data =_clientManager.GetListItems<AdvertisingBannerItem,AdvertisingBannerData>(Schema.AdvertisingBanner,filter: $“id eq ‘{bannerId}’”); - Here everything comes correctly from squidex.
After I change one field, I try to insert the changes back and get an error, what could be the problem ?
I’ll add screenshots
Should update content by id
- [+] Self hosted with docker
- Self hosted with IIS
- Cloud version
Version: 7.13.0.0
