Unittest with Squidex.ClientLibrary-19.1.0
Hello,
I’m trying to create mock objects of Model class using latest version of Squidex.ClientLibrary v19.1.0.
In Squidex.ClientLibrary v13.0.0, I’m able to create mock object of Model chass using below code:
var clientManager =new SquidexClientManager(new SquidexOptions{…});
var modelObjectClient = clientManager.CreateContentsClient<Model, ModelData>(“ExampleSchema”);
var modelObject = await clientManager.CreateAsync(squidexAuthorCurrentVersion,ContentCreateOptions.AsPublish);
However, the same class (“SquidexClientManager”) isn’t available in v19.1.0.
I need help in how may I create mock object of a Model class using Squidex.ClientLibrary-19.1.0 ?
Thank you
the client manager has been renamed to SquidexClient:
Thank you, Sebastian.
