Unhandled exception. System.IO.IOException: Function not implemented on M1 mac
I have pulled the latest squidex docker image on a m1 mac and get the following error on startup.
at System.IO.FileSystemWatcher.StartRaisingEvents()
at System.IO.FileSystemWatcher.StartRaisingEventsIfNotDisposed()
at System.IO.FileSystemWatcher.set_EnableRaisingEvents(Boolean value)
at Microsoft.Extensions.FileProviders.Physical.PhysicalFilesWatcher.TryEnableFileSystemWatcher()
at Microsoft.Extensions.FileProviders.Physical.PhysicalFilesWatcher.CreateFileChangeToken(String filter)
at Microsoft.Extensions.FileProviders.PhysicalFileProvider.Watch(String filter)
at Microsoft.Extensions.Configuration.FileConfigurationProvider.<.ctor>b__1_0()
at Microsoft.Extensions.Primitives.ChangeToken.OnChange(Func`1 changeTokenProducer, Action changeTokenConsumer)
at Microsoft.Extensions.Configuration.FileConfigurationProvider…ctor(FileConfigurationSource source)
at Microsoft.Extensions.Configuration.Json.JsonConfigurationSource.Build(IConfigurationBuilder builder)
at Microsoft.Extensions.Configuration.ConfigurationBuilder.Build()
at Microsoft.Extensions.Hosting.HostBuilder.BuildAppConfiguration()
at Microsoft.Extensions.Hosting.HostBuilder.Build()
at Squidex.Program.Main(String[] args) in /src/src/Squidex/Program.cs:line 18
qemu: uncaught target signal 6 (Aborted) - core dumped
  • [x ] Bug report
  • [x ] Self hosted with docker
Version: 6.7.0
There is a feature request already, but I need support with that, because I do not own a mac: [HELP_WANTED] Provide Docker ARM Image: Function not implemented exception when launching via docker-compose
