- [x] Bug report
I’m getting a deserialization error when querying data using a flattened context and a dynamic content client in the .NET SDK. The error is "ArgumentException: The value “Sandra” is not of type “Newtonsoft.Json.Linq.JObject” and cannot be used in this generic collection. (Parameter ‘value’)"
No error on Deserialization.
- Create a simple schema called “mylittlepony”
- Create a field on that schema called “name”
- Create a piece of content based on “mylittlepony” with the name “Sandra” and publish etc.
- Use the C# client manager with CreateDynamicContentsClient for the “mylittlepony” schema
- Create a query context with Flatten enabled i.e QueryContext.Default.Flatten();
- Observe error
- [ X ] Self hosted with IIS
Version: 4.5.1 (Squidex), 5.3.0 (SquidexClientLibrary)
- [ X ] Chrome (desktop)
This issue doesn’t happen with GraphQL, I believe it is because the returned root object is always nested so the dynamic map works.
I had tried to do that earlier albeit with variations other than a JToken. This appears to be working as expected now.
