Unable to login with fresh IIS installation for 4.5.1
  • [ X] Checked the logs and have provided the logs if I found something suspicious there
  • [X ] Bug report
I navigate to the local Squidex URL and click on “Login to Squidex”. A pop up is displayed, where I enter the initial credentials as this is the first time to login.
The login window doesn’t go away
Once the creditentials are provided, I should be able to log in to the system
Follow the instructions provided in the IIS installation guide
Set the appSettings.Production.json to the following
appSettings production configuration
“urls”: {
* The url where your squidex installation is available at.
“baseUrl”: “http://localhost:8081”
“identity”: {
* Disable authentication with google, github and microsoft login.
“googleClient”: “”,
“googleSecret”: “”,
“githubClient”: “”,
“githubSecret”: “”,
“microsoftClient”: “”,
“microsoftSecret”: “”,
* Initial username and password.
“adminEmail”: "admin@squidex.io",
“adminPassword”: “save1q2w3e$R”,
“assetStore”: {
“folder”: {
* Define where to store the assets.
“path”: “C:\Squidex_4_5_1\assets”
“orleans”: {
* Disable clustering!
“clustering”: “Development”
  • [ ] Self hosted with docker
  • [X] Self hosted with other version
Version: [4.5.1]
  • [X] Chrome (desktop)
  • In Mongo DB, the admin user is created with the following details
Identity_Users Document
{"_id":{"$oid":“5f3ae7260e1c422a6046e736”},
“UserName”:"admin@squidex.io",
“NormalizedUserName”:"ADMIN@SQUIDEX.IO",
“Email”:"admin@squidex.io",
“NormalizedEmail”:"ADMIN@SQUIDEX.IO",
“PasswordHash”:“AQAAAAEAACcQAAAAEF90pNylRnYGqinpyv+N8RtrvcKxWXTHizzMy6uM588ovu1eJ9AsGL/7qPgJAL4wrA==”,"
SecurityStamp":“WQ44AJS3FJZFPTYMASCAQUAXKA3DNTPO”,
“ConcurrencyStamp”:“548530bc-4560-4526-964d-83944afd3564”,
“LockoutEnabled”:true,
“Claims”:[{“Type”:“urn:squidex:name”,“Value”:“admin@squidex.io”},{“Type”:“urn:squidex:permissions”,“Value”:“squidex.admin.*”}],“Tokens”:[],“Logins”:[],“Roles”:[]}
  • In the log file, there is the following error:
TokenDeserializeException in log file
“logLevel”: “Error”,
“message”: “An exception was thrown while deserializing the token.”,
“eventId”: {
"id": 7,
"name": "TokenDeserializeException"
“app”: {
"name": "Squidex",
"version": "4.5.1.0",
"sessionId": "c80d3025-04fc-4de1-ba60-6540892137b7"
“web”: {
"requestId": "|bbbd417d-4dbff54f9ef47b1d.",
"requestPath": "/Account/Login",
"requestMethod": "GET",
"routeValues": {
  "area": "IdentityServer",
  "action": "Login",
  "controller": "Account"
“timestamp”: “2020-08-17T20:39:52Z”,
“category”: “Microsoft.AspNetCore.Antiforgery.DefaultAntiforgery”,
“exception”: {
"type": "Microsoft.AspNetCore.Antiforgery.AntiforgeryValidationException",
"message": "The antiforgery token could not be decrypted.",
"stackTrace": "   at Microsoft.AspNetCore.Antiforgery.DefaultAntiforgeryTokenSerializer.Deserialize(String serializedToken)\r\n   at Microsoft.AspNetCore.Antiforgery.DefaultAntiforgery.GetCookieTokenDoesNotThrow(HttpContext httpContext)"
  • In the log file, it is indicated that it is a production environment
Hosting environment log
“logLevel”: “Information”,
“message”: “Hosting environment: Production”,
“envName”: “Production”,
“app”: {
"name": "Squidex",
“timestamp”: “2020-08-17T20:23:20Z”,
“category”: “Microsoft.Hosting.Lifetime”
  • In the log file, there are the typical Identity call back traces (I can add the details, if needed)
To be honest, I have no idea what this is, I do not use IIS myself and do not test it regularly on IIS. I have to install it myself and just test it out.
Thank you for your prompt response Sebastian. I appreciate that you will try it out at your end. In the meantime, I will try it again with freshly downloaded binaries and let you know, if something changes. Thanks.
Are you running with https? I was not able to get it working without https.
But it works with firefox and http. It seems that Chrome just does not sets the cookie.
I was running it with http as it was a local machine.
I can confirm that it runs with firefox and http as well as with Chrome and https. I think this Chrome issue might be related to a recent Chrome update as it used to work before on different system.
Thank you again for your help!
In general http is not recommended anymore. There is a very nice IIS integration for lets encrypt that I have used before. No good excuse anymore to use http :wink:
