As I mentioned: The documentation will be improved, but the CLI exposes all commands. for example
.\sq.exe
Required command was not provided
Usage: dotnet sq.dll [command]
Commands:
apps Manages apps.
assets Manages assets.
backup Manage backups.
config Manage configurations.
content Manage contents.
info Shows information about the CLI.
log Analyze request log.
openlib Openlibrary example.
schemas Manage schemas.
sync Synchronizes apps.
twitter Manage twitter.
Use "dotnet sq.dll [command] --help" for more information about a command.
Then you can dig in
.\sq.exe sync
Synchronizes apps.
Usage: dotnet sq.dll sync [command]
Commands:
describe Describe the synced folder.
in Imports the app from a folder.
new Creates a new folder with sample files how to create an app from json files.
out Exports the app to a folder.
targets List all targets.
Use "dotnet sq.dll sync [command] --help" for more information about a command.
And get the targets
.\sq.exe sync targets
(I just added the description, so the output will look differently)
| Name | Description |
| assetfolders | Synchronizes all asset folders, even if they do not contain assets. |
| assets | Synchronizes all assets and creates asset folders if they do not exist yet. |
| schemas | Synchronizes all schemas, but not the content. |
| app | Synchronize all app settings: clients, contributors, roles, languages and asset scripts. But not: workflows. |
| contents | Synchronizes all content items across all schemas. |
| rules | Synchronizes all rules, but not rule events. |
| workflows | Synchronizes all workflows from the app settings. |
Count: 7
Or you use --help
for a single command:
.\sq.exe sync in --help
Usage: dotnet sq.dll sync in [options] <folder>
Arguments:
folder <TEXT>
The target folder to synchronize.
Options:
--app <TEXT>
The name of the app. If not provided then app configured in currentApp gets created.
-t | --targets (Multiple) <TEXT>
The targets to sync, e.g. 'contents' or 'schemas'. Use 'sync targets' to view all targets.
--language (Multiple) <TEXT>
The content language to synchronize.
--content-action <CONTENTACTION>
Defines how to handle content.
Allowed values: Upsert, UpsertPatch, Create, Update, Patch
--delete
Use this flag to also delete entities.
--patch-content
Make content updates as patch.
--recreate
Use this flag to also recreate entities.
--skip-assets
Use this flag to sync asset folders but not assets.
--update-current-client
Also update the client that is used during the sync process.
--emulate
Use this flag to not make any updates and to emulate the changes.
