- [x] Bug report
‘Total’ on Contents view (and querying with the API and Squidex.ClientLibrary) is showing vastly more results than there actually are.
Clicking on ‘Next page’ shows an empty page with only back button and page size showing:
Deleting permanently via the API is not failing, but it isn’t deleting anything. Deleting via the UI is working.
‘Total’ matches the number of documents.
No idea sorry!
- [x] Self hosted with docker
Version: 7.2.0
- [x] Chrome (desktop)
This has happened a few times for us in shared development environments, so may not be a bug with Squidex (was happening when on v7.1.0 too so not a regression) but perhaps is caused by us performing concurrent actions like deleting and inserting at the same time, deploying halfway through a deletion etc. Just wondered if you had any ideas on how we could get into this state? Also if you had any thoughts on how we could fix it that doesn’t require deleting and recreating the schema?
