- [+] Read the following guideline: Troubleshooting and Support | Squidex. I understand that my support request might get deleted if I do not follow the guideline.
- Bug report
- Performance issue
When I add a link to the ‘Editor URL,’ it doesn’t display. The iframe where it should appear applies styles that hide the editor. There are no errors in the console. What could be the problem?
- [+] Self hosted with docker
- Self hosted with IIS
- Cloud version
- Chrome (desktop)
- Chrome (Android)
- Chrome (iOS)
- Firefox
- Safari (desktop)
- Safari (iOS)
- IE
- Edge
If you provide your code, I can have a look.
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width, initial-scale=1">
<script src="https://cloud.squidex.io/scripts/editor-sdk.js"></script>
<script src="js/tinymce.min.js"></script>
</head>
<body>
<textarea name="content" id="editor"></textarea>
<script>
const field = new SquidexFormField();
tinymce.init({
selector: 'textarea#editor',
height: 400,
deprecation_warnings: true,
plugins: [
'advlist autolink link image lists charmap print preview hr anchor pagebreak',
'searchreplace wordcount visualblocks visualchars code fullscreen insertdatetime media table paste nonbreaking',
'table emoticons template help',
toolbar:
'undo redo | styleselect | bold italic | alignleft aligncenter alignright alignjustify | link | ' +
'bullist numlist outdent indent | image | print preview media fullpage | ' +
'forecolor backcolor emoticons | help' +
'casechange checklist code formatpainter paste table | vanna',
setup: (editor => {
editor.on('init', () => {
field.onValueChanged(function (value) {
editor.setContent(value || '');
field.onDisabled(function (disabled) {
editor.setMode(disabled ? 'readonly' : 'design');
editor.on('change', () => {
const value = editor.getContent();
field.valueChanged(value);
editor.on('blur', () => {
field.touched();
</script>
</body>
</html>
A link to the tiny editor would also help. Just to be sure we have the same version
here’s a link to the editor itself http://88.99.96.121:1111/tiny.html - it’s a test one for production used the same one with https and domain only,
I could not use your version, because I run under https locally. so I copied it to my server, changed the html to use the CDN instead and it just works fine.
what version of squidex do you have ?
I have “version”: “7.13.0.0”
because of one extension in the browser was such a bug, removed the extension everything works. Thanks for your help, the matter is closed
