- [X] Checked the logs and have provided the logs if I found something suspicious there
- [X] Bug report
Once in a while, our users are getting “Failed to load schema” errors in Squidex. The response time of the web app goes up to 10+ seconds according to Azure, while normally it’s <1 second.
Sometimes the problem goes away by itself, sometimes we need to restart the app service.
No errors while using Squidex.
Not easy to reproduce, it happens randomly.
- [X] Self hosted with docker
Version: 4.2.0
- [X] Chrome (desktop)
Log level is set to Information and up. Couple of warnings about Orleans timeouts:
Response did not arrive on time in 00:00:30 for message: Request S127.0.0.1:11111:323927419*cli/3d72f395@9aa42091->S127.0.0.1:11111:323927419*grn/70B001E1/f1aa11a5@c5db9f9f #261976: . Target History is: <S127.0.0.1:11111:323927419:*grn/70B001E1/f1aa11a5:@c5db9f9f>. About to break its promise.
Orleans is set to Development mode as we only have 1 node.
We’re hosting on Linux App Services in a Docker Container on Azure. Mongo is on a separate VM and we’re using Premium storage for assets.
