- [x] Performance issue
When we insert a record via the API and then fetch it immediately after the records does not always exist. The second attempt to get the record always finds it though.
We would expect a way request atomicity of the operations so when they are run in sequence and the first one returns the response it is understood that the record has been created and distributed to all data shards (or whatever the system has)
Create and fetch a record with a script, run the script a hundred times.
Cloud -
App Name: currently crn-1949 but could be any app really.
- [x] Cloud version
- [ ] Chrome (desktop)
