- [ ] Used code blocks with ``` to format my code examples like JSON or logs properly.
Hi @Sebastian,
Is it possible to sync-out contents with the history using CLI tool and sync-in. Backup and restore wouldn’t work for us as we are planning to migrate from a quite older version.
If possible, it would be very helpful if you could share the instructions.
Many thanks,
Manula.
- [ ] Chrome (desktop)
