- [X] Bug report
On a website we haven’t touched the code in years, suddenly it is failing to parse the JSON as it is not matching the structure it used to be
Should be able to parse successfully but is failing since last deployment on SquidEx side.
No public facing way of demonstrating problem
IIS
Chrome and Firefox
Can you roll back last night’s deployment?
