Dear Sebastian, good morning,
I currently work on CI/CD pipelines to deploy our current solutions and I have one problem :
Here are 2 environments I am using :
- One local k8s cluster (I have tried with minikube and the built-on docker k8s cluster, and I get the same result. OS : Windows 10 Pro)
- One AKS (Azure Cluster), use for staging and production
I can deploy without any problem all my containers on AKS, but I each and every time I try to publish to my local cluster, I get this message for my Squidex image :
"Error: failed to start container “squidex”: Error response from daemon: OCI runtime create failed: container_linux.go:348: starting container process caused “exec: “./Squidex”: stat ./Squidex: no such file or directory”: unknown "
- When I run the same image on docker only it works like a charm.
- I have tried some others solutions like not using the alpine image and change the entry point command … no luck it couldn’t find dotnet …
I have googled around but so far I didn’t find a solution yet.
If you have any clue of what’s going on I would really appreciate a bit of help as now, I feel a bit stuck.
Thanks a lot for the awesome work you have carried out with Squidex and good day,
Aldric
