- Bug report
- Performance issue
status code 408 for APIs request
- Self hosted with docker
- Self hosted with IIS
- Cloud version
- Chrome (desktop)
- Chrome (Android)
- Chrome (iOS)
- Firefox
- Safari (desktop)
- Safari (iOS)
- IE
- Edge
Sorry, I have never received a warning about that. I have OneUptime and Google Cloud agents that monitor the state and create notifications and there was nothing. I have restarted the servers and hope it has been fixed.
I have restarted the nodes. Not sure if it helps.
I did some debugging last night and found that some endpoints were still working, mostly the less heavy ones.
The larger ones and a lot of graphQL stuff seemed to timeout.
Not sure if that helps you.
Yes, the load on the database was really go up like crazy:
I have restarted the nodes one by one, but of course this does not solve the root cause.
Seems to be fixed now,
Keep us posted on your findings on the root cause. I will need the information for a report to the clients
Yes, but it will be super difficult. The CPU is not going up anymore, which is very strange.
No worries!
Probably not related by it seemed to happen exactly at the time that I added new content to a project. Probably just a coincidence… thought I broke everything at the time, was fun haha
Not so funny
…but not very likely.
I have not found the root cause yet, but I have created an alert for CPU usage.
