[STALE] Scripts execute maybe a error
I have met a script execute error.
scheme
            "name": "publishedAt",
            "properties": {
                "isRequired": false,
                "isRequiredOnPublish": false,
                "isHalfWidth": false,
                "fieldType": "DateTime",
                "editor": "DateTime"
            "isLocked": false,
            "isHidden": false,
            "isDisabled": true,
            "partitioning": "invariant"
change script
            var data = ctx.data;
            if (data.publishedAt.iv === null && ctx.status === "Published") {
                data.publishedAt.iv = new Date().toISOString().split('.')[0]+"Z";
                replace(data);
create a new post and publish to test, but assign the value of publishedAt in the final.
    "data": {
        "title": {
            "iv": "test"
        "bio": {
            "iv": null
        "body": {
            "iv": null
        "nutrition": {
            "iv": []
        "publishedAt": {
            "iv": null
        "slug": {
            "iv": "test"
Version: current cloud version
When I use the below change script, it works well.
            if (data.publishedAt.iv == null && ctx.status === "Published") {
                replace(data);
This shows that '===′ does not seem to work properly.
Where is the difference?
Here strict equality (===).
Are you sure it is null and not just undefined?
