I managed to build Squidex v7 for both AMD and ARM. Would appreciate if someone can check it out a verify that it works. Tried to build on both windows and mac and seems to work fine.
Dockerfile:
ARG SQUIDEX_TAG=
ARG SQUIDEX_FRONTEND_TAG=
## Backend build env
FROM --platform=$BUILDPLATFORM mcr.microsoft.com/dotnet/sdk:7.0 as backend-build
ARG BUILDPLATFORM
ARG TARGETPLATFORM
ARG SQUIDEX_TAG
SHELL ["/bin/bash", "-c"]
WORKDIR /
COPY ./dotnet_rdi_translator.sh ./dotnet_rdi_translator.sh
RUN git clone --depth 1 --branch $SQUIDEX_TAG https://github.com/Squidex/squidex.git
RUN source /dotnet_rdi_translator.sh ${TARGETPLATFORM} && \
dotnet publish /squidex/backend/src/Squidex/Squidex.csproj \
-c Release \
-r $DOTNET_RUNTIME \
--self-contained \
-p:PublishSingleFile=true \
-p:version=$SQUIDEX_TAG \
-o /publish/
## Build Frontend
# NOTE: Use TARGETPLATFORM to ensure npm install is done for expected TARGET (e.g. linux/arm64).
# TODO: Is this needed, or can it be done any other way?
FROM --platform=$TARGETPLATFORM squidex/frontend-build:$SQUIDEX_FRONTEND_TAG as frontend-build
ARG TARGETPLATFORM
WORKDIR /
ENV CONTINUOUS_INTEGRATION=1
# Copy frontend from backend-env stage, so we don't have to install git and clone repository again.
# TODO: Any more efficient way of doing this?
COPY --from=backend-build /squidex/frontend/package*.json /squidex/frontend/
RUN cd /squidex/frontend/ && \
npm install --loglevel=error --force
COPY --from=backend-build /squidex/frontend/ /squidex/frontend/
npm run test:coverage && \
npm run build
RUN cp -a /squidex/frontend/build /build/
## Runtime env
FROM --platform=$TARGETPLATFORM mcr.microsoft.com/dotnet/runtime-deps:7.0-alpine as runtime
ARG TARGETPLATFORM
ARG SQUIDEX_TAG
WORKDIR /app
ENV DOTNET_SYSTEM_GLOBALIZATION_INVARIANT=false
RUN apk add icu
# Copy from build stages
COPY --from=backend-build /publish/ /app/
COPY --from=frontend-build /build/ /app/wwwroot/build/
EXPOSE 80
EXPOSE 443
ENTRYPOINT ["/app/Squidex"]
ENV EXPOSEDCONFIGURATION__VERSION=$SQUIDEX_TAG
dotnet_rdi_translator:
#!/bin/sh
# Takes the provided first argument and translates docker platform to dotnet runtime identifier (rid)
case "$1" in
"linux/amd64") DOTNET_RUNTIME="linux-musl-x64" ;;
"linux/arm64") DOTNET_RUNTIME="linux-musl-arm64" ;;
*) DOTNET_RUNTIME="$1"
esac
export DOTNET_RUNTIME
DockerCompose for ARM:
version: "3.5"
services:
squidex_mongo:
image: "mongo:6"
volumes:
- /etc/squidex/mongo/db:/data/db
networks:
- internal
restart: unless-stopped
squidex_squidex:
image: "squid/squidex:7.8.2-arm64"
environment:
- URLS__BASEURL=https://${SQUIDEX_DOMAIN}:8443
- EVENTSTORE__TYPE=MongoDB
- EVENTSTORE__MONGODB__CONFIGURATION=mongodb://squidex_mongo
- STORE__MONGODB__CONFIGURATION=mongodb://squidex_mongo
- IDENTITY__GITHUBSECRET=${SQUIDEX_GITHUBSECRET}
- ASPNETCORE_URLS=http://+:8443
healthcheck:
test: ["CMD", "curl", "-f", "http://localhost:8443/healthz"]
start_period: 60s
depends_on:
- squidex_mongo
volumes:
- /etc/squidex/assets:/app/Assets
networks:
- internal
squidex_proxy:
image: squidex/caddy-proxy
ports:
- "8080:80"
- "8443:443"
environment:
- SITE_ADDRESS=${SQUIDEX_DOMAIN}
- SITE_SERVER="squidex_squidex:8443"
volumes:
- /etc/squidex/caddy/data:/data
- /etc/squidex/caddy/config:/config
depends_on:
- squidex_squidex
networks:
- internal
networks:
internal:
driver: bridge
DockerCompose for AMD:
version: "3.5"
services:
squidex_mongo:
image: "mongo:6"
volumes:
networks:
- internal
squidex_squidex:
image: "squid/squidex:7.8.2-amd64"
environment:
healthcheck:
start_period: 60s
depends_on:
- squidex_mongo
volumes:
networks:
- internal
squidex_proxy:
ports:
- "8080:80"
- "8443:443"
environment:
volumes:
depends_on:
- squidex_squidex
networks:
- internal
networks:
internal:
driver: bridge
build.sh:
#!/bin/sh
SQUIDEX_TAG=7.8.2
SQUIDEX_FRONTEND_TAG=18.10
# Build and tag multi-platform
docker buildx build --platform linux/amd64,linux/arm64 --build-arg "SQUIDEX_TAG=$SQUIDEX_TAG" --build-arg "SQUIDEX_FRONTEND_TAG=$SQUIDEX_FRONTEND_TAG" -t squid/squidex:${SQUIDEX_TAG} .
# Build and tag amd64 only. This will be quick, since all amd64 layers has already been built locally.
docker buildx build --load --platform linux/amd64 --build-arg "SQUIDEX_TAG=$SQUIDEX_TAG" --build-arg "SQUIDEX_FRONTEND_TAG=$SQUIDEX_FRONTEND_TAG" -t squid/squidex:$SQUIDEX_TAG-amd64 .
# Build and tag arm64 only. This will be quick, since all arm64 layers has already been built locally.
docker buildx build --load --platform linux/arm64 --build-arg "SQUIDEX_TAG=$SQUIDEX_TAG" --build-arg "SQUIDEX_FRONTEND_TAG=$SQUIDEX_FRONTEND_TAG" -t squid/squidex:$SQUIDEX_TAG-arm64 .
