Hi
We’re having some problems with our self-hosted version of Squidex in Azure. What we’re seeing is once a day or so the squidex web api starts to fail e.g. unable to load schemas, content etc. At the time this starts to happen the logs start to fill up with this event, that repeats every few seconds:
2021-07-12T10:07:33.753149352Z: [INFO] {
2021-07-12T10:07:33.753152952Z: [INFO] "logLevel": "Warning",
2021-07-12T10:07:33.753156852Z: [INFO] "message": "Dropping expired message Status Response S127.0.0.1:11111:363115450*grn/Squidex.Domain.Apps.Entities.Schemas.DomainObject.SchemaDomainObjectGrain/0\u002B722f9229-65ef-494f-9aac-b66c50c62c37--4f704ced-ebbe-49c1-a89f-d31b5e91ce93@4873d6bc-\u003ES127.0.0.1:11111:363115450*cli/eab536a2@e047f684 #3982180 at phase Send",
2021-07-12T10:07:33.753161452Z: [INFO] "eventId": {
2021-07-12T10:07:33.753165252Z: [INFO] "id": 101038,
2021-07-12T10:07:33.753169052Z: [INFO] "name": "Orleans.Messaging.Drop.Expired"
2021-07-12T10:07:33.753172952Z: [INFO] },
2021-07-12T10:07:33.753177152Z: [INFO] "message": "Status Response S127.0.0.1:11111:363115450*grn/Squidex.Domain.Apps.Entities.Schemas.DomainObject.SchemaDomainObjectGrain/0\u002B722f9229-65ef-494f-9aac-b66c50c62c37--4f704ced-ebbe-49c1-a89f-d31b5e91ce93@4873d6bc-\u003ES127.0.0.1:11111:363115450*cli/eab536a2@e047f684 #3982180",
2021-07-12T10:07:33.753182452Z: [INFO] "phase": "Send",
2021-07-12T10:07:33.753186352Z: [INFO] "timestamp": "2021-07-12T10:07:33Z",
2021-07-12T10:07:33.753190152Z: [INFO] "app": {
2021-07-12T10:07:33.753193952Z: [INFO] "name": "Squidex",
2021-07-12T10:07:33.753197752Z: [INFO] "version": "5.6.0.0",
2021-07-12T10:07:33.753201552Z: [INFO] "sessionId": "6c9e84fd-d970-436f-b938-566921171c0a"
2021-07-12T10:07:33.753205552Z: [INFO] },
2021-07-12T10:07:33.753209252Z: [INFO] "category": "Orleans.Messaging"
2021-07-12T10:07:33.753213052Z: [INFO] }
If we restart the web app running the docker container then everything starts working again and this event stops repeating in the logs.
Do you have any thoughts on what might cause this please?
Thanks
Andrew
