Squidex on docker works with http. on https it is not working
I am able to setup squidex and mongodb on docker. (only http).
I am unable to setup on https. can you please help me with this.
Regards,
Pawan Kumar B H
How do you deploy it? If you use this dockerfile you get https included:
It uses a nginx proxy and lets encrypt to issue the cert automatically.
But when you write “does not work” I am not sure how I can help you.
after using the above compose file. i get below error when i cur.
root@testingsquidex:~# curl localhost
503 Service Temporarily Unavailable
nginx/1.14.1
You need a public domain and then use the domain to access squidex, otherwise it gets not served by nginx.
i worked around it. thanks sebastian.
How, what have you done? I also tried the docker-compose file yesterday and it was working.
I have also added a few things to the logs: https://docs.squidex.io/01-getting-started/installation/install-docker
