I’m trying to setup Squidex in Azure with using CosmosDB but without any success.
I have AppService with running Squidex in a docker container with the following configuration:
"name": "ASSETSTORE__AZUREBLOB__CONNECTIONSTRING",
"value": "***",
"slotSetting": false
"name": "ASSETSTORE__TYPE",
"value": "AzureBlob",
"name": "DOCKER_REGISTRY_SERVER_URL",
"value": "https://index.docker.io",
"name": "EVENTSTORE__COSMOSDB__CONFIGURATION",
"value": "https://**.documents.azure.com",
"name": "EVENTSTORE__COSMOSDB__MASTERKEY",
"value": "***",
"name": "EVENTSTORE__TYPE",
"value": "CosmosDB",
"name": "IDENTITY__ADMINEMAIL",
"value": "**",
"name": "IDENTITY__ADMINPASSWORD",
"value": "**",
"name": "IDENTITY__GITHUBCLIENT",
"value": "",
"name": "IDENTITY__GOOGLECLIENT",
"value": "",
"name": "IDENTITY__MICROSOFTCLIENT",
"value": "",
"name": "STORE__MONGODB__CONFIGURATION",
"value": "**",
"name": "URLS__BASEURL",
"value": "https://**.azurewebsites.net",
"name": "WEBSITE_HTTPLOGGING_RETENTION_DAYS",
"value": "30",
"name": "WEBSITES_ENABLE_APP_SERVICE_STORAGE",
"value": "false",
Also I’ve created storage account and cosmosdb resource (Azure Cosmos DB for MongoDB API).
I can run Squidex but when I try to create app I get 500 error.
2019-07-22T11:21:04.772356899Z "logLevel": "Error",
2019-07-22T11:21:04.772361099Z "message": "Connection id \"0HLOEIQMHMDB7\", Request id \"0HLOEIQMHMDB7:00000001\": An unhandled exception was thrown by the application.",
2019-07-22T11:21:04.772365099Z "eventId": {
2019-07-22T11:21:04.772368399Z "id": 13,
2019-07-22T11:21:04.772371699Z "name": "ApplicationError"
2019-07-22T11:21:04.772375299Z },
2019-07-22T11:21:04.772444199Z "connectionId": "0HLOEIQMHMDB7",
2019-07-22T11:21:04.772451299Z "traceIdentifier": "0HLOEIQMHMDB7:00000001",
2019-07-22T11:21:04.772454899Z "exception": {
2019-07-22T11:21:04.772466599Z "type": "Microsoft.Azure.Documents.DocumentClientException",
2019-07-22T11:21:04.772521700Z "message": "Sql api is not supported for this database account\r\nActivityId: 6706a8dc-dfcf-412f-851e-eaa21016588f, Microsoft.Azure.Documents.Common/2.4.0.0, Linux/3.8.4 documentdb-netcore-sdk/2.4.0",
2019-07-22T11:21:04.774702614Z "stackTrace": " at Microsoft.Azure.Documents.GatewayStoreClient.ParseResponseAsync(HttpResponseMessage responseMessage, JsonSerializerSettings serializerSettings, DocumentServiceRequest request)\n at Microsoft.Azure.Documents.GatewayStoreClient.InvokeAsync(DocumentServiceRequest request, ResourceType resourceType, Uri physicalAddress, CancellationToken cancellationToken)\n at Microsoft.Azure.Documents.GatewayStoreModel.ProcessMessageAsync(DocumentServiceRequest request, CancellationToken cancellationToken)\n at Microsoft.Azure.Documents.Client.DocumentClient.ProcessRequestAsync(DocumentServiceRequest request, IDocumentClientRetryPolicy retryPolicyInstance, CancellationToken cancellationToken)\n at Microsoft.Azure.Documents.Query.DocumentQueryExecutionContextBase.ExecuteQueryRequestInternalAsync(DocumentServiceRequest request, IDocumentClientRetryPolicy retryPolicyInstance, CancellationToken cancellationToken)\n at Microsoft.Azure.Documents.Query.DocumentQueryExecutionContextBase.ExecuteQueryRequestAsync(DocumentServiceRequest request, IDocumentClientRetryPolicy retryPolicyInstance, CancellationToken cancellationToken)\n at Microsoft.Azure.Documents.Query.DefaultDocumentQueryExecutionContext.ExecuteOnceAsync(IDocumentClientRetryPolicy retryPolicyInstance, CancellationToken cancellationToken)\n at Microsoft.Azure.Documents.Query.DefaultDocumentQueryExecutionContext.<>c__DisplayClass8_0.<<ExecuteInternalAsync>b__0>d.MoveNext()\n--- End of stack trace from previous location where exception was thrown ---\n at Microsoft.Azure.Documents.BackoffRetryUtility`1.ExecuteRetryAsync(Func`1 callbackMethod, Func`3 callShouldRetry, Func`1 inBackoffAlternateCallbackMethod, TimeSpan minBackoffForInBackoffCallback, CancellationToken cancellationToken, Action`1 preRetryCallback)\n at Microsoft.Azure.Documents.ShouldRetryResult.ThrowIfDoneTrying(ExceptionDispatchInfo capturedException)\n at Microsoft.Azure.Documents.BackoffRetryUtility`1.ExecuteRetryAsync(Func`1 callbackMethod, Func`3 callShouldRetry, Func`1 inBackoffAlternateCallbackMethod, TimeSpan minBackoffForInBackoffCallback, CancellationToken cancellationToken, Action`1 preRetryCallback)\n at Microsoft.Azure.Documents.Query.DefaultDocumentQueryExecutionContext.ExecuteInternalAsync(CancellationToken token)\n at Microsoft.Azure.Documents.Query.DocumentQueryExecutionContextBase.ExecuteNextAsync(CancellationToken cancellationToken)\n at Microsoft.Azure.Documents.Query.ProxyDocumentQueryExecutionContext.ExecuteNextAsync(CancellationToken token)\n at Microsoft.Azure.Documents.Linq.DocumentQuery`1.ExecuteNextPrivateAsync[TResponse](CancellationToken cancellationToken)\n at Squidex.Infrastructure.EventSourcing.FilterExtensions.QueryAsync[T](IQueryable`1 queryable, Func`2 handler, CancellationToken ct)\n at Squidex.Infrastructure.EventSourcing.CosmosDbEventStore.QueryAsync(String streamName, Int64 streamPosition) in /src/src/Squidex.Infrastructure.Azure/EventSourcing/CosmosDbEventStore_Reader.cs:line 75\n at Squidex.Infrastructure.States.Persistence`2.ReadEventsAsync() in /src/src/Squidex.Infrastructure/States/Persistence{TSnapshot,TKey}.cs:line 106\n at Squidex.Infrastructure.States.Persistence`2.ReadAsync(Int64 expectedVersion) in /src/src/Squidex.Infrastructure/States/Persistence{TSnapshot,TKey}.cs:line 66\n at Squidex.Infrastructure.Commands.DomainObjectGrainBase`1.OnActivateAsync(Guid key) in /src/src/Squidex.Infrastructure/Commands/DomainObjectGrainBase.cs:line 61\n at Orleans.LifecycleSubject.WrapExecution(CancellationToken ct, Func`2 action)\n at Orleans.LifecycleSubject.OnStart(CancellationToken ct)\n at Orleans.Runtime.Catalog.CallGrainActivate(ActivationData activation, Dictionary`2 requestContextData)\n at Orleans.Runtime.Scheduler.AsyncClosureWorkItem.Execute()\n at Orleans.Runtime.Catalog.InitActivation(ActivationData activation, String grainType, String genericArguments, Dictionary`2 requestContextData)\n at Orleans.OrleansTaskExtentions.<ToTypedTask>g__ConvertAsync|4_0[T](Task`1 asyncTask)\n at Squidex.Infrastructure.Commands.GrainCommandMiddleware`2.ExecuteCommandAsync(TCommand typedCommand) in /src/src/Squidex.Infrastructure/Commands/GrainCommandMiddleware.cs:line 41\n at Squidex.Infrastructure.Commands.GrainCommandMiddleware`2.HandleAsync(CommandContext context, Func`1 next) in /src/src/Squidex.Infrastructure/Commands/GrainCommandMiddleware.cs:line 29\n at Squidex.Domain.Apps.Entities.Apps.Indexes.AppsByNameIndexCommandMiddleware.HandleAsync(CommandContext context, Func`1 next) in /src/src/Squidex.Domain.Apps.Entities/Apps/Indexes/AppsByNameIndexCommandMiddleware.cs:line 50\n at Squidex.Domain.Apps.Entities.Apps.Indexes.AppsByNameIndexCommandMiddleware.HandleAsync(CommandContext context, Func`1 next) in /src/src/Squidex.Domain.Apps.Entities/Apps/Indexes/AppsByNameIndexCommandMiddleware.cs:line 66\n at Squidex.Infrastructure.Commands.GrainCommandMiddleware`2.HandleAsync(CommandContext context, Func`1 next) in /src/src/Squidex.Infrastructure/Commands/GrainCommandMiddleware.cs:line 34\n at Squidex.Domain.Apps.Entities.Contents.ContentCommandMiddleware.HandleAsync(CommandContext context, Func`1 next) in /src/src/Squidex.Domain.Apps.Entities/Contents/ContentCommandMiddleware.cs:line 33\n at Squidex.Infrastructure.Commands.GrainCommandMiddleware`2.HandleAsync(CommandContext context, Func`1 next) in /src/src/Squidex.Infrastructure/Commands/GrainCommandMiddleware.cs:line 34\n at Squidex.Domain.Apps.Entities.Assets.AssetCommandMiddleware.HandleCoreAsync(CommandContext context, Func`1 next) in /src/src/Squidex.Domain.Apps.Entities/Assets/AssetCommandMiddleware.cs:line 134\n at Squidex.Domain.Apps.Entities.Assets.AssetCommandMiddleware.HandleAsync(CommandContext context, Func`1 next) in /src/src/Squidex.Domain.Apps.Entities/Assets/AssetCommandMiddleware.cs:line 124\n at Squidex.Domain.Apps.Entities.Apps.Invitation.InviteUserCommandMiddleware.HandleAsync(CommandContext context, Func`1 next) in /src/src/Squidex.Domain.Apps.Entities/Apps/Invitation/InviteUserCommandMiddleware.cs:line 47\n at Squidex.Web.CommandMiddlewares.EnrichWithSchemaIdCommandMiddleware.HandleAsync(CommandContext context, Func`1 next) in /src/src/Squidex.Web/CommandMiddlewares/EnrichWithSchemaIdCommandMiddleware.cs:line 54\n at Squidex.Web.CommandMiddlewares.ETagCommandMiddleware.HandleAsync(CommandContext context, Func`1 next) in /src/src/Squidex.Web/CommandMiddlewares/ETagCommandMiddleware.cs:line 59\n at Squidex.Infrastructure.Commands.InMemoryCommandBus.PublishAsync(ICommand command) in /src/src/Squidex.Infrastructure/Commands/InMemoryCommandBus.cs:line 42\n at Squidex.Areas.Api.Controllers.Apps.AppsController.PostApp(CreateAppDto request) in /src/src/Squidex/Areas/Api/Controllers/Apps/AppsController.cs:line 96\n at Microsoft.AspNetCore.Mvc.Internal.ActionMethodExecutor.TaskOfIActionResultExecutor.Execute(IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments)\n at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.InvokeActionMethodAsync()\n at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.InvokeNextActionFilterAsync()\n at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.Rethrow(ActionExecutedContext context)\n at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)\n at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.InvokeInnerFilterAsync()\n at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.InvokeNextExceptionFilterAsync()\n at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.Rethrow(ExceptionContext context)\n at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)\n at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.InvokeNextResourceFilter()\n at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.Rethrow(ResourceExecutedContext context)\n at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)\n at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.InvokeFilterPipelineAsync()\n at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.InvokeAsync()\n at Microsoft.AspNetCore.Builder.RouterMiddleware.Invoke(HttpContext httpContext)\n at NSwag.AspNetCore.Middlewares.SwaggerDocumentMiddleware.Invoke(HttpContext context)\n at Microsoft.AspNetCore.Builder.Extensions.MapMiddleware.Invoke(HttpContext context)\n at Squidex.Web.Pipeline.EnforceHttpsMiddleware.InvokeAsync(HttpContext context, RequestDelegate next) in /src/src/Squidex.Web/Pipeline/EnforceHttpsMiddleware.cs:line 28\n at Microsoft.AspNetCore.Builder.UseMiddlewareExtensions.<>c__DisplayClass5_1.<<UseMiddlewareInterface>b__1>d.MoveNext()\n--- End of stack trace from previous location where exception was thrown ---\n at Squidex.Web.Pipeline.LocalCacheMiddleware.InvokeAsync(HttpContext context, RequestDelegate next) in /src/src/Squidex.Web/Pipeline/LocalCacheMiddleware.cs:line 30\n at Microsoft.AspNetCore.Builder.UseMiddlewareExtensions.<>c__DisplayClass5_1.<<UseMiddlewareInterface>b__1>d.MoveNext()\n--- End of stack trace from previous location where exception was thrown ---\n at Squidex.Web.Pipeline.RequestLogPerformanceMiddleware.InvokeAsync(HttpContext context, RequestDelegate next) in /src/src/Squidex.Web/Pipeline/RequestLogPerformanceMiddleware.cs:line 33\n at Microsoft.AspNetCore.Builder.UseMiddlewareExtensions.<>c__DisplayClass5_1.<<UseMiddlewareInterface>b__1>d.MoveNext()\n--- End of stack trace from previous location where exception was thrown ---\n at Microsoft.AspNetCore.Builder.Extensions.MapMiddleware.Invoke(HttpContext context)\n at Microsoft.AspNetCore.Builder.Extensions.MapWhenMiddleware.Invoke(HttpContext context)\n at Microsoft.AspNetCore.Builder.Extensions.MapWhenMiddleware.Invoke(HttpContext context)\n at Microsoft.AspNetCore.Builder.Extensions.MapWhenMiddleware.Invoke(HttpContext context)\n at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpProtocol.ProcessRequests[TContext](IHttpApplication`1 application)"
Also in a CosmosDB I can see only Squidex collection without SquidexContent. Is it normal?
Version of Squidex is 3.0.0.0
Do you have any ideas what can be wrong?
