Squidex Events not being sent
When saving changes in the schema, events are not being generated when inspecting the rules. As a result, upon saving the History section version increments, but does not show the historical changes after clicking Save.
From what we’re noticing, issue started on Friday 21st August (at least events were generated till that day in the morning).
Also adding a reference to this thread which is the same issue - Squidex has stopped sending events
Upon saving or publishing of content, an event should be generated and it gets logged under the Rules Logs page.
  1. Go on any schema and create a new entry
  2. Fill in the details
  3. Click Save
  4. History tab changes are not recorded but version increments with each change
  5. Go to Rules page
  6. Check the log, and no events are logged
App Name: All our aps, but ivagaming, ivastaging for example
Version: [7.0.0.0]
I have restarted the worker and it looks okay for me now.
Yes can confirm that its working fine now, thank you Sebastian
