- [ x] Checked the logs and have provided the logs if I found something suspicious there
- [ x] Documentation issue or request
I am running the Standalone (no proxy) docker-compose image behind a Traefik reverse proxy. Docker is running on a self-hosted Ubuntu server.
Note that the domain is a subdomain - so subdomain.real-domain.io. However, I have tried it with the base domain and the issue persists.
The site is accessible via the https URL. When I try to login, I get the IDX20803: Unable to obtain configuration error in the logs. This is the case with username/password and Google login.
When I manually go to the link in the address specified in the error message, I am able to access the configuration data.
When I set the SQUIDEX_PROTOCOL to HTTP and remove the https redirection of Traefik, it works. However, I don’t want the page to be unsecure.
Here is the error:
IDX20803: Unable to obtain configuration from: \u0027https://url-of-website/identity-server/.well-known/openid-configuration\u0027."
Here is the docker-compose file I use for setup:
version: ‘2.1’
services:
squidex_mongo:
image: mongo:latest
volumes:
- mongo:/data/db
networks:
- internal
restart: unless-stopped
squidex_squidex:
image: "squidex/squidex"
hostname: ${SQUIDEX_DOMAIN}
environment:
- URLS__BASEURL=${SQUIDEX_PROTOCOL}://${SQUIDEX_DOMAIN}/
- URLS__ENFORCEHTTPS=${SQUIDEX_FORCE_HTTPS}
- EVENTSTORE__MONGODB__CONFIGURATION=mongodb://squidex_mongo
- STORE__MONGODB__CONFIGURATION=mongodb://squidex_mongo
- IDENTITY__GITHUBSECRET=${SQUIDEX_GITHUBSECRET}
- IDENTITY__SHOWPII=true
- IDENTITY__PRIVACYURL=http://research.squidex.com/privacy.html
- REBUILD_APPS=true
depends_on:
- squidex_mongo
volumes:
- squidex_assets:/app/Assets
networks:
- internal
- external-network
labels:
- "traefik.enable=true"
- "traefik.http.routers.headless-secured.entrypoints=websecure"
- "traefik.http.routers.headless-secured.rule=Host(`url-of-website`)"
- "traefik.http.routers.headless-secured.tls.certresolver=challenge"
- "traefik.http.routers.headless-secured.tls=true"
- "traefik.http.routers.headless.entrypoints=web"
- "traefik.http.routers.headless.rule=Host(`url-of-website`)"
- "traefik.http.middlewares.compress.compress=true"
- "traefik.http.middlewares.redirect.redirectscheme.scheme=https"
- "traefik.http.routers.headless.middlewares=compress,redirect"
- "traefik.http.routers.headless-secured.middlewares=compress"
networks:
external-network:
external: true
internal:
driver: bridge
volumes:
mongo:
squidex_assets:
Here is the env file:
SQUIDEX_PROTOCOL=https
SQUIDEX_FORCE_HTTPS=False
SQUIDEX_DOMAIN=url-of-website
SQUIDEX_ADMINEMAIL=example-email
SQUIDEX_ADMINPASSWORD=example-password2009!!
SQUIDEX_GITHUBCLIENT=
SQUIDEX_GITHUBSECRET=
SQUIDEX_GOOGLECLIENT=
SQUIDEX_GOOGLESECRET=
SQUIDEX_MICROSOFTCLIENT=
SQUIDEX_MICROSOFTSECRET=
- [ x] Self hosted with docker
- [x ] Chrome (desktop)
- [ x] Chrome (iOS)
- [ x] Safari (iOS)
- [ x] Edge
