- [x] Bug report
The squidex container stops with the following error :
File name: 'System.Data.SqlClient, Version=4.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a'
at System.Reflection.RuntimeAssembly.InternalLoad(ObjectHandleOnStack assemblyName, ObjectHandleOnStack requestingAssembly, StackCrawlMarkHandle stackMark, Boolean throwOnFileNotFound, ObjectHandleOnStack assemblyLoadContext, ObjectHandleOnStack retAssembly)
at System.Reflection.RuntimeAssembly.InternalLoad(AssemblyName assemblyName, RuntimeAssembly requestingAssembly, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, AssemblyLoadContext assemblyLoadContext)
at System.Reflection.RuntimeAssembly.InternalLoad(AssemblyName assemblyName, StackCrawlMark& stackMark, AssemblyLoadContext assemblyLoadContext)
at System.Runtime.Loader.AssemblyLoadContext.LoadFromAssemblyName(AssemblyName assemblyName)
at McMaster.NETCore.Plugins.Loader.AssemblyLoadContextBuilder.PreferDefaultLoadContextAssembly(AssemblyName assemblyName)
at McMaster.NETCore.Plugins.PluginLoader.CreateLoadContextBuilder(PluginConfig config)
at McMaster.NETCore.Plugins.PluginLoader..ctor(PluginConfig config)
at McMaster.NETCore.Plugins.PluginLoader.CreateFromAssemblyFile(String assemblyFile, Action`1 configure)
at Squidex.Infrastructure.Plugins.PluginLoaders.LoadPlugin(String pluginPath, AssemblyName[] sharedAssemblies)
at Squidex.Infrastructure.Plugins.PluginManager.Load(String path, AssemblyName[] sharedAssemblies) in /src/src/Squidex.Infrastructure/Plugins/PluginManager.cs:line 40
at Squidex.Pipeline.Plugins.PluginExtensions.AddSquidexPlugins(IMvcBuilder mvcBuilder, IConfiguration config) in /src/src/Squidex/Pipeline/Plugins/PluginExtensions.cs:line 42
at Squidex.Config.Web.WebServices.AddSquidexMvcWithPlugins(IServiceCollection services, IConfiguration config) in /src/src/Squidex/Config/Web/WebServices.cs:line 79
at Squidex.Startup.ConfigureServices(IServiceCollection services) in /src/src/Squidex/Startup.cs:line 40
at System.RuntimeMethodHandle.InvokeMethod(Object target, Span`1& arguments, Signature sig, Boolean constructor, Boolean wrapExceptions)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Microsoft.AspNetCore.Hosting.MethodInfoExtensions.InvokeWithoutWrappingExceptions(MethodInfo methodInfo, Object obj, Object[] parameters)
at Microsoft.AspNetCore.Hosting.ConfigureServicesBuilder.InvokeCore(Object instance, IServiceCollection services)
at Microsoft.AspNetCore.Hosting.ConfigureServicesBuilder.<>c__DisplayClass9_0.<Invoke>g__Startup|0(IServiceCollection serviceCollection)
at Microsoft.AspNetCore.Hosting.ConfigureServicesBuilder.Invoke(Object instance, IServiceCollection services)
Squidex working normally
- [x] Self hosted with docker
Version: [7.0.2]
- [ ] Chrome (desktop)
Chart version: 1.0.0 , appVersion: “7.0.2”
The values of the chart is
labels:
service:
type: ClusterIP
port: 80
deployment:
replicaCount: 1
selectors:
component: squidex
partOf: ""
version: ""
image:
repository: squidex/squidex
tag: "7.0.2"
pullPolicy: IfNotPresent
securityContainerContext:
allowPrivilegeEscalation: false
runAsNonRoot: true
runAsUser: 10001
capabilities:
drop:
- ALL
containerPort: 8080
resources:
limits:
cpu: 1000m
memory: 1Gi
requests:
cpu: 500m
memory: 500Mi
nodeSelector: {}
tolerations: []
clusterSuffix: cluster.local
mongodb:
mongoDbHost: mongodb-0,mongodb-1,mongodb-2:27017
monguser:
mongopassword:
mongodb: squidex_db
ingress:
## If true, Squidex Ingress will be created.
enabled: true
## Squidex Ingress annotations
annotations:
kubernetes.io/ingress.class: nginx
# kubernetes.io/tls-acme: "true"
hostName: squidex.local
tls: []
# - secretName: chart-example-tls
# hosts:
# - chart-example.local
env:
# Define the type of the event store
EVENTSTORE__TYPE: MongoDb
EVENTSTORE__MONGODB__DATABASE: "squidex_db"
# CREATE LOCAL ADMIN USER
IDENTITY__ADMINEMAIL: "squidex_admin"
IDENTITY__ADMINPASSWORD: "squidex_admin_password"
IDENTITY__ADMINRECREATE: true # Recreate the admin if it does not exist or the password does not match
IDENTITY__ALLOWPASSWORDAUTH: "true" # Enable password auth. Set this to false if you want to disable local login, leaving only 3rd party login options
IDENTITY__LOCKAUTOMATICALLY: "false" # Lock new users automatically, the administrator must unlock them
IDENTITY__SHOWPII: true # Set to true to show PII (Personally Identifiable Information) in the logs
IDENTITY__PRIVACYURL: "https://squidex.io/privacy" # The url to you privacy statements, if you host squidex by yourself
# Settings for Google auth (keep empty to disable)
IDENTITY__GOOGLECLIENT: null
IDENTITY__GOOGLESECRET: null
# Settings for Github auth (keep empty to disable)
IDENTITY__GITHUBCLIENT: null
IDENTITY__GITHUBSECRET: null
# Settings for Microsoft auth (keep empty to disable)
# NOTE: Tennant is optional for using a specific AzureAD tenant
IDENTITY__MICROSOFTCLIENT: null
IDENTITY__MICROSOFTSECRET: null
IDENTITY__MICROSOFTTENANT: null
# Settings for your custom oidc server
IDENTITY__OIDCNAME: null
IDENTITY__OIDCAUTHORITY: null
IDENTITY__OIDCCLIENT: null
IDENTITY__OIDCSECRET: null
IDENTITY__OIDCMETADATAADDRESS: null
IDENTITY__OIDCSCOPES: [] # ["email"]
IDENTITY__OIDCRESPONSETYPE: null # id_token or code
IDENTITY__OIDCGETCLAIMSFROMUSERINFOENDPOINT: false
IDENTITY__OIDCSINGOUTREDIRECTURL: null
LETSENCRYPT_HOST: null
LETSENCRYPT_EMAIL: null
# LOGGING SETTINGS
LOGGING__LEVEL: INFORMATION # Trace, Debug, Information, Warning, Error, Fatal
LOGGING__HUMAN: false # Setting the flag to true, enables well formatteds json logs
LOGGING__COLORS: false # Set to true, to use colors
LOGGING__LOGREQUESTS: true # Set to false to disable logging of http requests
LOGGING__STOREENABLED: true # False to disable the log store
LOGGING__STORERETENTIONINDAYS: 90 # The number of days request log items will be stored
LOGGING__STACKDRIVER__ENABLED: false # True, to enable stackdriver integration
LOGGING__OTLP__ENABLED: false # True, to enable OpenTelemetry Protocol integration
LOGGING__OLTP__ENDPOINT: null # The endpoint to the agent
LOGGING__APPLICATIONINSIGHTS__ENABLED: false # True, to enable application insights integraon
LOGGING__APPLICATIONINSIGHTS__CONNECTIONSTRING: null # "instrumentationkey=keyvalue"
# Define the clustering type
ORLEANS__CLUSTERING: MongoDB # SUPPORTED: MongoDB, Development
ORLEANS__KUBERNETES: true # Tell Orleans it is running in kubernetes
# Define the type of the read store
STORE__MONGODB__CONTENTDATABASE: "squidex_content_db"
# Assets
ASSETSTORE__TYPE: MongoDb
URLS__BASEURL: http://squidex.local # Set the base url of your application, to generate correct urls in background process
URLS__ENFORCEHTTPS: false # Set it to true to redirect the user from http to https permanently
Many thanks,
