- [ X ] Checked the logs and have provided the logs if I found something suspicious there
- [ X ] Documentation issue or request
I’m trying to update a field through the client library that is set to an input type. We’re building a migration tool to migrate schemas and fields over to other apps.
This input type field has changed, so we have to update it inside of other apps. The problem is that I get this error when trying to update the field type:
"message": "Properties must be of type 'Squidex.Domain.Apps.Core.Schemas.StringFieldProperties\r\nParameter name: newProperties",
The code to do this update is:
await this.masterSchemasClient.PutFieldAsync(applicationName, schemaName, targetFieldId, updateDto);
The code works fine when it’s doing things like toggling off and on the required state. But when it comes to switching the type of input it breaks. Am I missing something here or is there another way to update the field type itself?
- [ X ] Self hosted with IIS
Version: Latest
